My version of an Ultrasonic Record Cleaner - Page 2 - diyAudio
Old 25th August 2012, 02:40 PM   #11
Where did you source your cork spacers? I've got the rest of my parts for my UC build coming. I'm still trying to work out spacers. My UC cleaner is a L&R Sweepzone 200 I picked up off of eBay.
Kevin T
Old 25th August 2012, 11:04 PM   #12
bbftx is offline bbftx  United States
bbftx's Avatar
Originally Posted by blueskiespbd View Post
That is what I want to build. Being impatient I want to use some spacers and do 2 or even 4 records at once. Do you think that will work?
David
David,
I think as long as you leave about 1 inch between records, you can get good results cleaning multiple records at a time.
Old 25th August 2012, 11:14 PM   #13
bbftx's Avatar
Kevin T
Kevin,
My spacers were described as 4" cork rounds, 3mm thick. ordered from Consumer Crafts. It's easy to glue as many as you want together to create whatever spacer thickness you need. I used a drill press to drill the center hole.
But there is a problem with these. They aren't 4" in diameter. They're about 1/8" shy, and therefore don't completely cover the record label!
This isn't a problem for me, as my rotation speed is slow (12 min per revolution), that the liquid drains off before it can drip over the label.
But, you might want to search somewhere for a 4.5" cork round to be safe. I don't know if there is such a beast.
Old 26th August 2012, 03:01 PM   #14
Thanks. I'll check some of the local craft stores to see what I can come up with. My rotation motor is a 1 RPM so I may need to ensure full label coverage just in case. I still have a few parts to get before I'm done, but so far things look promising to finish by next weekend.
Kevin T
Old 27th August 2012, 01:02 AM   #15
LFM is offline LFM  Canada
Default record cleaner
I too have been looking for some spacers that would also protect the label but be rigid enough to be clamped with sufficient force to make sure the record rotates. I have seen where someone cut their own spacers out of a plastic cutting board that you can find just about anywhere. You would just use a hole saw to make them. I think I will use drink coasters which are 4.25 inches square and are made of thin hardboard with a cork coating. They are available at Walmart and other places and are really cheap. I'll probably make a little circle jig for my router to make them round. A small area of the label will be exposed at 4 spots since they are just a tiny bit small. I don't think there will be any problem with slow rotation and I really want the lead out groove to be spic and span. I'll submerge the record very close to the label.
Old 27th August 2012, 03:47 AM   #16
I have ordered my machine from EBabe and will get the motor tomorrow. I am using Ikea cutting boards to work as spacers. I plan on experimenting with the quanity and spacing for best results.
Old 27th August 2012, 03:48 PM   #17
bbftx's Avatar
If you're going to the trouble of cutting the spacers, it might be cheaper to buy cork sheet or wood, rather than finished products like cutting boards or coasters.
Another option would be to buy cork stoppers.
I've ordered these from the UK: 110mm by 105mm tapered cork stoppers - they should cover the record label completely and very little of the lead out groove. They are just a touch over 1" thick, which is my optimal spacing.
No.37 Natural Cork Stopper 110mm from Just Cork No. 37 Large
A US option is 4.5" x 4.25" tapered cork stoppers. They will cover slightly more of the lead out groove at the big end. They are 1-1/4 inch thick.
Size 56 Jar Cork Stoppers, Standard | WidgetCo®
The UK ones end up about the same delivered cost for me. The stoppers are cheaper, offset by higher shipping. But the sizing looks perfect to me.
Note the US and UK seem to have different systems of numbering stoppers.
Old 27th August 2012, 03:56 PM   #18
bbftx's Avatar
LFM - Aside from my spacer suggestions in the last message, I'll pass on the fact that I've found very little clamping force is required to make the records spin. The agglomerated cork I'm using so far is non-slip (we'll see about the UK natural cork I ordered). In the photos of my unit, you'll see white nylon spacers that I'm using. These had a 1/4 ID when bought at the hardware store.
I reamed the one nearest my motor just slightly so that it was a press fit over my 9/32" drill rod spindle. The one on the other end was reamed to a resistance fit over the 9/32 drill rod. It can be slid on after the records are in place, and pushed up against my outside label protector. It can easily be set snug enough to slightly compress the cork assure record rotation --- no other type of firm clamping is required.
Old 27th August 2012, 04:29 PM   #19
I found some 4" round weatherproof Carlon outlet covers at Home Depot. They were $2.54 each. I just drilled a 1/4" hole in the center and super glued the supplied foam ring to the back. I get full label coverage with these covers. I bought 8 of them so that I can load 4 LPs on the spindle for cleaning.
Kevin T
Old 27th August 2012, 04:39 PM   #20
Here's the link:
Amazon.com: Carlon Round Weatherproof Cover (E365C-CAR): Home Improvement
I made myself a record cleaner Sclalars Analogue Source 231 20th February 2017 05:01 PM
My DIY record cleaner. mattjk Analogue Source 105 9th March 2016 04:05 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 03:28 AM
diy ultrasonic cleaner, not using bought unit 3GGG Analogue Source 0 10th January 2011 09:28 AM
Ultrasonic Parts cleaner... DIY??? pk386 Everything Else 1 10th May 2004 06:55 PM
Copyright ©1999-2017 diyAudio
