Porsche Design Phonostage - diyAudio
Old 11th August 2012, 03:26 AM   #1
6L6 is offline 6L6  United States
6L6's Avatar
Default Porsche Design Phonostage
Well, the case is, anyway...
This is nothing more than an Elliott Sound Products Project P06 phonostage fed by a Project P05-B PSU. (In a salvaged LaCie portable hard drive case.)
http://sound.westhost.com/project06.htm
http://sound.westhost.com/project05b.htm
This is not going to be the final wiring, nor the final back panel - I will make something a bit prettier and most likely without the captive output cable. This is just prototype. A LED for the front needs to be added, and a fuse in the PSU input, and probably some other things that are escaping memory right now.
At this stage I can say that it works, and not much else - I literally had it playing for 10min, and then had to shut down the workbench due to my toddler going to sleep. It is very quiet, no hum, and at first glance (listen) sounds very nice indeed.
Take a look - As I said, it isn't finished yet.
Old 11th August 2012, 03:32 AM   #2
kach22i is offline kach22i  United States
kach22i's Avatar
I don't understand where the case came from originally.
Tubes and Martin Logan's
Old 11th August 2012, 03:38 AM   #3
6L6's Avatar
LaCie, maker of external computer hard drives, has a series of their products in cases styled by Porsche Design. This is one from a few years ago.
Old 11th August 2012, 05:54 AM   #4
great idea. i have some of those lying around too.
Old 26th August 2012, 01:40 AM   #5
kach22i's Avatar
Thanks, I've never seen them before.
Great adaptation.
Old 26th August 2012, 04:28 AM   #6
6L6's Avatar
I have had a chance to listen to this project some more, and I would like to say that it sounds very good indeed!
The circuit has no hum, except when you place the enclosure close to a transformer.
The biggest complaint is that the enclosure is too light to hold up a set or two of heavy interconnects, I will try to get some used lead wheel weights from a local tire shop and add some mass that way.
More photos when I construct and change out the back panel.
Vintage Car Radio Telefunken Porsche 356 tiefbassuebertr Car Audio 0 22nd June 2010 02:55 PM
phonostage with 150VDC B+ alexg Tubes / Valves 9 18th August 2007 01:13 AM
phonostage design lt cdr data Analogue Source 1 20th April 2005 09:48 AM
Re-designing my phonostage rho Analogue Source 7 2nd April 2005 04:42 PM
Found porsche audio amp. Ford_V6 Car Audio 2 8th June 2003 07:10 PM
Copyright 1999-2017 diyAudio
