Yaqin MS-22b Phono Amp
Old 9th August 2012, 07:04 PM   #11
SDIESEL77 is offline SDIESEL77  Ireland
So basically, you removed the ground from the 2 original (black) cables on the input and connected the ground directly from the input RCA to the chassis ?
Old 9th August 2012, 07:28 PM   #12
DF96 is online now DF96  England
No, the opposite of that! The incoming phono cable should not be connected to any chassis anywhere. It should connect to the preamp circuit, and use whatever ground arrangements that has. The RCA sockets should be isolated from chassis so only grounded via the internal cable and the preamp circuitry.
Old 9th August 2012, 07:44 PM   #13
humm ok, any particular place where I could solder then the input ground on the circuit?
A photo of your circuit maybe ?
Old 9th August 2012, 07:47 PM   #14
What do you mean by input ground? Are you asking about how to connect the incoming phono signal to the circuit ground? If so, I have already answered that - it goes to the circuit ground, not the chassis.
If you are asking about the circuit ground then that depends on your circuit, not my circuit!
Old 9th August 2012, 08:21 PM   #15
As mentionned above, I just tried to disconnect the 2 input sockets from the pcb and tried the pre amp like this.
Unfortunately, the humm is still here and even slightly louder...
Here is the schematic of the pre amp:
Old 9th August 2012, 08:54 PM   #17
The signal return (or screen) of the phono cable should connect to the bottom end of R11/R14 as that is the point which sets the input signal ground reference.
If wired incorrectly it is possible that C15 injects ripple at this point.
Old 9th August 2012, 09:09 PM   #18
Guys,
Got it !
If you look at one of the pix I sent, there is a ground yellow cable that is going from the pcb ground to the chassis.
I disconnected it from the chassi and that's it: no more hum !!!! ;-) (so happy now)
I don't know why the hell YAQIN put this cable here !
However, I still have this "poc" in my speakers when I m changing channels from aux to phono...
Steph
Old 10th August 2012, 11:04 AM   #19
pegwill is offline pegwill
Default Yaqin MS-22b Phono Amp
Hi
What I actually ment was that if you look at the input phono connections your'll see that the ground/negatives are soldered together. I split these apart from each other and the hum was gone.
I tried disconnecting the wire to the chasis but in my case it did not make any difference.
Still trying to trace the source of the hum from my DIY SUT - you wouldn't think it would be so difficult. However trial and error I suppose.
Old 11th August 2012, 07:34 AM   #20
Originally Posted by pegwill View Post
Hi
I'll try today and will let you know the result on mine
Yaqin MS-22b Phono AmpHide this!Advertise here!
Yaqin MS 12B phono amp- reviews Zero One Analogue Source 106 26th February 2017 10:42 PM
YAQIN MS-22B. Any thoughts, please? vincula Tubes / Valves 13 6th February 2016 11:45 PM
FS: Yaqin MS-12B Tube Phono Preamp tronan Swap Meet 0 21st July 2012 08:47 PM
Help - YAQIN MS-20L schematic pigeon_snake Tubes / Valves 4 11th January 2012 12:49 AM
Yaqin MS-300B SET amp Rodango Tubes / Valves 18 26th November 2010 08:09 AM
