RIAA Capacitors
RIAA Capacitors
Old 28th July 2012, 06:48 AM   #1
velvetsunrise is online now velvetsunrise  United Kingdom
Default RIAA Capacitors
Hi, Looking for some advice on riaa eq caps
Whilst looking for highish value capacitors for a mc phono amp i am about to build, i came across some yellow Phillips KS 444 1% Tol Polystyrenes, these on the face of it seemed suitable for my application.
After reading a few threads on the subject, here, i discvovered that some think steel leads are bad for sound, i checked the Philips KS 444, Hmm! the leads are magnetic.
I also have some Russion Polystyrol box type, these are non magnetic, but i have read indifferent reports, Also i have the large Russian silver mica 0.5% Tol, the cases on these are steel, they are also large and difficult to mount on a PCB
I also came across some Vishay KP 461 1% Polypropylene, anyone know if these are magnetic?
And of course does it really matter?
Should i just stop worrying and use the Phillips KS444.
Which would you choose?
Old 29th July 2012, 06:51 AM   #2
Calvin is offline Calvin  Germany
Calvin's Avatar
why not omit with throughhole Caps alltogether? Apart from some eletrolytics SMD-caps are easy to solder and they improve on parasitic parameters like pin-inductance and they are non-magnetic. See PEN and PPS types (Panasonic et al) as well as silver Micas (CD or BMC). Btw. large size is no quality sign in itself. Under certain circumstances large sized Caps make excellent HF-antennas.
Old 29th July 2012, 07:14 AM   #3
Hi Calvin,
I just sourced some suitably sized EMZ 1% Polypropylenes , hoping these will do the job. I may even mount the riaa networks on seperate small boards, that can be easily changed to try out different capacitor types.
Though i am not fully convinced that i could detect the presence of magnetic leadout wires, on an otherwise qualty component, but if alternatives are available, why take the chance.
Old 29th July 2012, 02:42 PM   #4
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Some of the Panasonic PP films have steel legs. Read the fine print of the specs to see where the copper lead versions begin.
RIAA CapacitorsHide this!Advertise here!
RIAA Capacitors...Jupiter HT and Cardas Golden Ratio chrismercurio Parts 0 16th August 2011 02:06 PM
help capacitors teflon for riaa alboran Parts 1 14th June 2010 01:49 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
