Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 16th October 2003, 08:26 AM   #1
Onvinyl's Avatar
Default How to calculate RIAA correctly?
has anybody an article, link or software where the calculating of parts values for the riaa filter is explained deeply for various concepts? That explanation should include the relevant surroundings like impedance of following stages etc.
I would really like to understand such things correctly, in existing designs as well as for trying own ideas.
greets & thanks,
Rudiger
Old 16th October 2003, 09:53 AM   #2
Electrons are yellow
peranders's Avatar
I have two Excel files, one for inverting RIAA amp and one for a non-inverting.
Anybody who wants these send me an email,
Do not post me too, me too, me too, me too, me too, me too, me too, me too, me too, me too, me too, me too, me too, me too, me too, etc here
Output is like this:
http://home5.swipnet.se/~w-50674/hif...diagram_ai.gif
http://home5.swipnet.se/~w-50674/hif...lerance_ai.gif
/Per-Anders (my first name) or P-A as my friends call me
BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb. Not too late to sign up. Sign up HERE
Old 16th October 2003, 10:48 AM   #3
Stanley P. Lipshitz.
On RIAA Equalization Networks.
Journal of the Audio Engineering Society, 27(6), June 1979.
Peter J. Baxandall
Comments on "On RIAA Equalization Networks"
Journal of the Audio Engineering Society, 29(1), Jan 1981.
Stanley P. Lipshitz
Author's Reply to "Comments on 'On RIAA Equalization Networks'"
Old 16th October 2003, 10:54 AM   #4
Onvinyl's Avatar
is the lipshitz article available online anywhere? Google did not find it.
Greets,
Rüdiger
Old 16th October 2003, 10:59 AM   #5
Not that I know of. If you do not want to order it from the AES, you will have to find a library that holds back issues of the AES journal.
ray
Old 16th October 2003, 11:03 AM   #6
peranders's Avatar
It's not very expensive to order from AES, a couple of dollars. I have ordered a couple of old articles and it has been a painless process and the pdf files have been nice scanned.
Old 16th October 2003, 12:50 PM   #7
Banned
The Lipshitz article deals with pole-zero interaction due to the effects of finite open-loop gain in a feedback arrangement.
If you want it to be accurate, passive EQ is the best choice. I have been able to construct EQs that were accurate to +/- 0.02 dB that way.
In any case, there is a hump between 200 and 500 Hz that is hard to remove. Doing so yields an accurate sound that few seem to like.
If you do go passive, somewhere I have a program that plots the output error. If you supply me with the values that you have, I could calculate it for you.
Jocko
Old 16th October 2003, 01:03 PM   #8
The Lipschitz article includes at least two passive networks.
ray.
Old 16th October 2003, 01:05 PM   #9
peranders's Avatar
My non-inverting Excel file takes this into account but it's tricky to really compensate for it.
As Jockpo says, it's easier to have separate filters for each time constant.
An example of this can be found in an application note somewhere at Analog Devices.
Old 16th October 2003, 01:31 PM   #10
ashok's Avatar
Default RIAA
If you go to the Beige Bag software site you will find several pages of info given by John Broskie about building active and passive RIAA circuits and how to simulate them. You could even download a trial version of Beige Bag's Spice software for free and try out the circuits and any modifications that you may want to try out. The circuit files shown can be opened with their software. It's great , easy to use. Try it out.
Cheers.
http://www.beigebag.com/resources.htm
AM
Thread Tools
How to correctly use WinISD Zero D Subwoofers 8 20th August 2009 02:07 PM
Am I using Unibox correctly? zimjj Multi-Way 0 7th February 2009 11:26 PM
Any articles on how to bias correctly PRNDL Tubes / Valves 4 1st February 2008 05:39 PM
Am I using UniBox correctly? needtubes Subwoofers 3 12th June 2005 02:02 AM
Are we looking at distortion correctly? mashaffer Solid State 24 14th July 2004 03:04 AM
Page generated in 0.10564709 seconds (79.97% PHP - 20.03% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
