Old 18th October 2003, 03:49 AM   #21
SY's Avatar
FETs don't glow, at least not for long.
Case closed!
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 18th October 2003, 06:40 PM   #22
Onvinyl's Avatar
So, anybody who can shine light on the passive riaa case I asked yesterday?
greets,
Rüdiger
Old 18th October 2003, 06:47 PM   #23
Banned
Could you be more specific?????
Jocko
Old 18th October 2003, 07:18 PM   #24
Onvinyl's Avatar
i try to understand the riaa network of
http://www.klaus-boening.de/html/sc...s.html#MKIIInew
With the given values and the aid of
http://www.kabusa.com/riaa.htm ,
R1 should be around 7,2 K. In Klaus' riaa there is no Resistor for R1; it seems that it's made of the output impedance of the previous stage. That impedance, with the Drain-Resistor of 4.7K, should be around 4.5K in a single-ended design.
So, how do we reach the desired 7.2K?
Rüdiger
Old 18th October 2003, 09:47 PM   #25
Speedskater's Avatar
Default RIAA
Go to the Hagerman Technology pages. www.hagtech.com.
Check out the following pages. (some of the links are hard to find)
"Bugle" Phono Preamp kit
"On Reference RIAA Networks"
"Cartridge Loading"
Kevin
Old 24th October 2003, 01:47 AM   #26
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
SY, you are right completely. But not only for RIAA accuracy, but for testing on stress signals (square waves) and for sonic evaluation also. For example “An Active Inverse RIAA Circuit”, TAA, 1991, January
Getting an inverse correct is a lot easier- you don't care much about noise or sonics, just freq response. There are some excellent published designs (I used one from AA), and building one up with 0.5% or better tolerance components (I used 0.1% for mine) and input and output buffers will get you something pretty nice without having to trim.
Old 5th November 2003, 12:26 PM   #27
dekkersj's Avatar
Default passive RIAA calculation
Hi, try this:
http://people.zeelandnet.nl/eschoest...ieve_RIAA.html
It is considered to be as exact as possible within the constrains of the schematic, ie. no capacitive loading of the circuitry by means of a Miller-capacitance of the following amplifier.
With regards,
Inde Deus Abest
Old 6th November 2003, 09:09 AM   #28
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by rfbrw
The Lipschitz article includes at least two passive networks.
ray.
I have got the article (written with a typewriter?), 58 pages, nothing is forgotten, so it seems but I haven't got the time to read it.
/Per-Anders (my first name) or P-A as my friends call me
Old 19th February 2006, 01:53 AM   #29
kjunom is offline kjunom  United States
Default Bugle phono RIAA done correctly?
I got the Haggerman Bugle phono board to play records again. The board looks very nice. The spec sheet says RIAA +/- 0.5 db from 30 Hz to 60 KHz. However when I simulate with the given values, it appears that the two shelf filters are set for the RIAA filter points, but the resulting frequency response does not meet the specifications of the RIAA table (using the Analog Devices data table) because of the second filter causing "extra" losses.
What's right - text book design or the standard? Is the playback standard correcting the recording interaction? Or did I do something wrong in my simulation?
The board uses 3 opamps with the above mentioned two section passive equalization, making changes easy.
If the standard is right my initial correction is to:
1. decrease the loss in the first shelf filter by increasing the "load" side resistor.
2. Decrease the first shelf filter capacitance to make up for the change in both frequency points caused by change #1.
3. Decrease the second capcitor value to push the second shelf filter effects out a little farther.
After this, discrete JFET RIAA, maybe the phono pearl. The Bugle is cheap and easy, and should have good entry level performance.
Old 19th February 2006, 11:02 AM   #30
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
There was a thread very recently on inverse RIAA:
Inverse RIAA
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
How to correctly use WinISD Zero D Subwoofers 18 24th April 2011 04:40 AM
Am I using Unibox correctly? zimjj Multi-Way 0 8th February 2009 12:26 AM
Any articles on how to bias correctly PRNDL Tubes / Valves 4 1st February 2008 06:39 PM
Am I using UniBox correctly? needtubes Subwoofers 3 12th June 2005 03:02 AM
Are we looking at distortion correctly? mashaffer Solid State 24 14th July 2004 04:04 AM
Page generated in 0.12146 seconds (81.22% PHP - 18.78% MySQL) with 10 queries
