dual cs5000
dual cs5000
Old 6th July 2012, 11:48 AM   #1
william13 is offline william13
Default dual cs5000
Question regarding automatic shut off:
When tone arm is moved from resting position to the periphery of record the platter spins. At the end of record the tonearm should rise and platter stop. Mine does this but the tonearm must be moved close to the spindle to make it shut off. What is proper adjustment please?
Old 7th July 2012, 11:39 AM   #2
auto off was fixed: thank you
Old 15th March 2013, 10:11 AM   #3
senzi65 is offline senzi65  Netherlands
Hi, can you tell me? How did you fix it????
Old 4th September 2013, 12:44 PM   #4
nbmz is offline nbmz
Thumbs down To adjust the auto shutoff...
I signed up to reply to this, as it took me a long time to figure it out myself...
There is a large flathead screw underneath the grey plastic shroud that surrounds the tonearm base. Take the rear plastic shroud out You will see a large flathead screw on one side, which is an adjustment for the spring tensioned light sensors that detect the tonearm movement towards the middle.
Have a look at it long enough and you will figure out how it works.
I had to adjust mine quite a bit, but now it stops at the end of the record.
Good luck
dual cs5000Hide this!Advertise here!
Dual CS5000 cueing problem dat260z Analogue Source 7 7th March 2018 12:27 AM
Dual CV120 amp + Dual CL180 speakers Miguelxj Multi-Way 0 8th December 2011 11:17 PM
Dual turntable dual cs741q help needed steelyjoe Analogue Source 0 8th August 2010 03:25 PM
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 02:48 AM
dual primary//dual secondary toroid larryg Chip Amps 22 6th September 2006 09:24 PM
