RIAA Head Amp Models (Phono Preamp) with only balanced XLR-Cannon Input Sockets
Old 5th July 2012, 06:24 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default RIAA Head Amp Models (Phono Preamp) with only balanced XLR-Cannon Input Sockets
I am looking for an overview of all models like the Jeff Rowland Cadence - go to
http://jeffrowlandgroup.com/Docs/CadenceManual.pdf
i. e. without unbalanced input sockets like RCA/cynch or BNC.
Who know such models so as the associated schematics - both as commercial products and diy projects.
On this forum I find only this:
Balanced XLR source RIAA
THE TRUE BALANCED SOURCE
balanced RIAA amp
OPA1632 for balanced RIAA preamp.?
Thank you very much for advices.
Old 6th July 2012, 12:28 PM   #2
As I note by my own websearch, there are only RIAA head amps with both kind of input sockets - i. e. balanced and unbalanced. But even such models are rare and not easy to find.
Here my URL-Overview:
Elektor "MC Vorverstärker" (MAT03/OP27 - issue in Germany: 1991, march, page 22)
ImageShack® - Online Photo and Video Hosting
Elektor mc phonopreamp
The Vacuum State Electronics RTP3 preamplifier
The Vacuum State Electronics Realtime preamplifier
“La Bohème ” (Klaus Böning)
schematics
German summary
Ultra-Low-noise-MC-Vorverstärker
http://www.transkommunikation.ch/dat...erstaerker.pdf
Thel Phono-X
Phonovorstufe von THEL
Mark Kelly's Balanced Phono Preamp
AQVOX Phono 2 Ci - part 1
AQVOX Phono 2Ci balanced current-mode MM/MC phonostage - Part 1 [English]
Emmeline XR-10B
Emmeline XR-10B - Ray Samuels Audio
Audio Note M2
Audio Note M2 Balanced Phono preamplifier | Stereophile.com
BAT VK-P10SE
http://www.balanced.com/products/pho...0SE/index.html
Basics:
Tube CAD Journal: Tube balanced phono stage, July 1999
Balanced input stage beneficial for unbalanced turntables?
Minimalist balanced phono preamp?
current amplifying phono stage
balanced phono stage?
Turntable Forum • balanced phono stage
AudiogoN Forums: What phono preamps are balanced
Ayre Acoustics Phono Cables
Old 6th July 2012, 05:01 PM   #3
Groove T is offline Groove T  Switzerland
Groove T's Avatar
Here with XLR only, the FM Acoustics FM 222
FM ACOUSTICS LTD. : : FM 222
Old 6th July 2012, 05:07 PM   #4
grufti is offline grufti  United States
grufti's Avatar
SY's His Master's Noise phono preamp is balanced. You can read his very detailed article about it on this site.
Old 6th July 2012, 06:07 PM   #5
mean you this URL ?
http://www.diyaudio.com/forums/diyau...no-preamp.html
Thank you for this advice:
http://www.fmacoustics.com/pdf/dat_2223.pdf
Old 7th July 2012, 05:14 AM   #6
grufti's Avatar
Yes.
Originally Posted by tiefbassuebertr View Post
Old 7th July 2012, 09:50 AM   #7
Yes.
Thank you for this advice.
I read there:
OK, I'll begin by turning off half my readers- the design will use an input transformer. This "impure" approach carries too many advantages to ignore, including nearly noise-free gain, galvanic isolation, and the opportunity to run the phono cartridge in a balanced mode without doubling the tube count. Running balanced inputs is an amazingly powerful technique to reject common-mode noise and is common studio practice for low-level mike signals.
Until now I always assumed, that such transformers was only helpful in cases, where a MC cartridge is in use (for step-up).
But obviously such transformers are otherwise also very helpful, especially for upgrade already exist tube RIAA head amps to get GND-free balanced inputs. Indeed - a very interesting approach.
Because there are a wide range of transformers on the marked, the main question is now for me follow:
What transformer is the best ??
Old 23rd April 2016, 11:33 AM   #8
any news?
Old 27th April 2016, 03:17 AM   #9
hazard500 is offline hazard500  Australia
any news?
If you are after a fully differential RIAA stage (just like the Jeff Rowland unit) then I HIGHLY RECOMMEND the design by forum member polyphaze.
PHOBOS, a balanced MC phono stage
Key advantages are:
1. Its high gain. No SUT required (nonetheless its still fully differential input.
2. Its differential all the way. The design quoted before by SY is a wonderful design, BUT it is singe ended. Yes it has a balanced input by virtue of its transformer, but everything down stream is single end.
I am getting the parts together to build this and will assemble in the next few weeks. So I haven't listened to it yet, but i am confident that this will be a winner.
RIAA Head Amp Models (Phono Preamp) with only balanced XLR-Cannon Input SocketsHide this!Advertise here!
Balanced input all DC coupled RIAA preamp FdW Analogue Source 167 28th April 2015 02:41 PM
How Can I connect A Balanced RIAA Phono Pre-Amp to a Phono Plug amp input jmartinbaugh Analogue Source 3 25th April 2011 02:24 PM
Balanced XLR source RIAA Stee Analog Line Level 25 11th October 2008 11:59 AM
Modifying a tape head preamp for phono input. roshan101 Analogue Source 2 16th April 2004 03:34 PM
XLr balanced input/output. How do I change...? Lito Multi-Way 2 20th June 2003 01:45 AM
