Old 22nd June 2012, 02:31 AM   #1
Default Thorens TD 166 mk2 vs Rega
How would a Thorens TD 166 mk2 in good original condition perform sonically against a more modern Rega 3; considering both tables are working to spec, and both have equivalent quality cartridges, cables, wiring, etc.
Would it be wise to buy a fully restored Thorens TD 166 mk2, or for similar money, get a new Rega Planar 3?
Is the Rega table better due to efficiencies in computer aided design, and modern synthetic materials, or is the steel, brass, rubber, and wood construction of the Thorens a more effective way to render quality sound? Maybe someone has done some extensive A/B comparisons and formed an opinion. I will be doing so in the near future.
Maybe they both measure well, and sound good, and it comes down to which presentation the listener prefers?
George
Old 25th June 2012, 01:45 AM   #2
Zoodle is offline Zoodle  Australia
A Rega can sound excellent with minimal fuss/care. For those who simply want to enjoy their records, I would suggest the Rega. Meanwhile, used Thorens decks show more variation in sound.
Since this is a DIY forum, I should mention that both turntables are upgradeable, but the hard core DIYer might find a Thorens to be a more satisfying subject due higher parts count, hence more areas for experiment. That said, upgrade parts and kits are available for the Rega (some from Rega themselves).
In either case, I recommend a brand new cartridge/stylus (even if modest) over a used one.
Old 28th June 2012, 02:35 AM   #3
Nanook is offline Nanook  Canada
Nanook's Avatar
There are no new Rega Planar 3 turntables. The P3-24 happened, then the RP-3. Both are reportedly improvements compared to the Planar 3. Measurements are less explanatory than listening. The newest Regas (RP-1, etc) benefit from better motors, plinths, etc, and improvements over the RB-300 and RB-250 tonearms.
With not much work a Thorens TD16X can nip at the heals of a LP12. It all depends on the time and money one is willing to invest.
stew -"A sane man in an insane world appears insane."
beginner help - thorens td 125 mk2 langers2004 Analogue Source 38 8th January 2012 09:42 PM
Thorens td-124 mk2 wavering pitch, help boidos Analogue Source 8 19th August 2011 04:16 AM
Need Thorens TD 166 Mk II info Freeman Z Analogue Source 1 29th August 2008 09:57 PM
Need help with Phono Cartridge for Thorens TD-166-MKII sonictonicmusic Analogue Source 4 27th March 2008 04:32 AM
Transformer for Thorens TD-166 MKII Peter Menting Analogue Source 5 30th August 2003 06:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
