Microphonic DIY Interconnect Suggestions? - diyAudio
Old 14th June 2012, 07:12 PM   #1
Default Microphonic DIY Interconnect Suggestions?
I recently built a set of single silver conductor shielded interconnects. I used teflon tube slightly larger than the silver wire on the assumption that a little air around the wire would add to the insulating powers of the teflon. Not sure if the rest of the construction matters, but the layers went: silver/teflon tube/teflon tape/copper conductor/larger teflon tube/copper drain/aluminum foil/shrink tube.
Anyway, to my dismay I've discovered that the interconnects are microphonic. If I bump or even touch them I hear it. I assume (!) it's the movement of the silver in the airspace of the smallest teflon tube. Has anyone here come across this? I hate to take them apart and modify them only to find the airspace wasn't the issue.
Old 14th June 2012, 07:19 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Perhaps the connector itself are oxide coated inside them???
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 14th June 2012, 07:19 PM   #3
SY's Avatar
Yes, I have. Tribolectricity is my hypothesis- the cure is the same, use polypropylene or vinyl instead of Teflon.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th June 2012, 10:32 PM   #4
Tribolectricity -- had to look it up. Silver and teflon are the worst pairing apparently. Well, damn! I think I'll try pulling off the plug ends, sliding out the solver wire, and somehow reinsulating it before sliding it back into the teflon. Excellent ideas! Yours, not mine. Thanks.
Old 15th June 2012, 03:55 AM   #5
aptquark's Avatar
dude...
My contribution to this site...if anyone is interested.
skip forward...alot of talking in the beginning.
Old 15th June 2012, 07:40 AM   #6
Send a message via MSN to sq225917 Send a message via Skype™ to sq225917
Used cotton tube.
Paradise Pre-reg PSU PCBs
Old 15th June 2012, 11:19 AM   #7
DF96 is offline DF96  England
So are we saying that the favourite (for some) conductor and the favourite (for some) insulator don't work well together, at least for a home-made (loosely structured?) cable? How unfortunate! Maybe I will stick to my cheap copper in PVC interconnects.
Which is the best gemotry for diy silver interconnect? mbl Everything Else 37 30th December 2010 11:40 PM
DIY Interconnect: 5 pin DIN to RCA Coober Everything Else 7 11th July 2008 04:04 PM
What is the best DIY Interconnect that I coul build? Guijs Everything Else 4 16th October 2005 05:11 PM
DIY RCA type interconnect cables Sir Trefor Parts 5 9th March 2005 09:18 PM
DIY Cable and Interconnect site ChrisVH Everything Else 11 13th March 2003 11:43 AM
Copyright 1999-2017 diyAudio
