Old 14th June 2012, 05:32 PM   #1
Einric is offline Einric  United States
Default Low Capacitance Interconnect
Hey everybody, here is the schematic equivalent of coaxial cable.
I'm trying to see if there really is a difference between interconnects with high capacitance and low capacitance.
Two capacitors in series will have total capacitance equal to less than the value of the smaller capacitor.
What would happen if a VERY low value capacitor was placed in series with the capacitance caused by the interconnect cable?
I'd be talking about something less than 1 pf very high quality capacitor.
Old 14th June 2012, 05:34 PM   #2
Stupid question....LOL!
The capacitance is a virtual one.
If I placed another capacitor in there it would be in parallel with the virtual capacitance.
Now I just need a theoretical capacitor to physically place in series with the virtual capacitance HAHAHA!!!
Old 14th June 2012, 05:50 PM   #3
KatieandDad's Avatar
At audio frequencies the capacitance is almost immaterial. 50R RG58 is as good IMO as most Snake Oil cables. It is the connectors at the end that make an appreciable difference.
Old 14th June 2012, 06:06 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
The nominal impedance of a coax cable is the sqrt of his inductance per meter, divided the capacitance per meter. If you choose a high Zo coax, it naturally will have lower capacitance than lower impedance ones.
LW1DSE
Old 18th June 2012, 04:47 PM   #5
kevinkr's Avatar
Actually there is one case where this is absolutely not true and that is between a MM phono cartridge or the secondary of an MC step up transformer and the input of a phono pre-amplifier. I've still not found what I consider the ideal cable for this application.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 18th June 2012, 05:36 PM   #6
DF96 is offline DF96  England
Cable capacitance is quite real, not "virtual". You can calculate it from theory, and measure it with a meter. How much difference it makes in a particular case depends mainly on the source impedance, which is why it can be a problem with pickup cartridges. Fortunately, some cartridges are designed to cope with capacitance.
If you put a small cap in series with the cable then you will get low capacitance and low signal too. Generally not what you want. The small cap and cable form a potential divider.
Old 18th June 2012, 09:02 PM   #7
kevinkr's Avatar
Originally Posted by DF96 View Post
<snip>
WRT to phono stages tube based designs usually have appreciable input capacitance due to miller capacitance if high mu triodes are used, and much less if a pentode or cascode connection are used. There may or may not be much input capacitance margin left by the time that is taken into account.
Old 18th June 2012, 11:45 PM   #8
sandyK is offline sandyK  Australia
Einric
If your requirements are for a cable longer than the typical 1Metre length, have a look at the Blue Jeans LC1. They are very well made, and far better value for money than most .
Alex
Stereo Cables at Blue Jeans Cable
Old 19th June 2012, 11:28 AM   #9
Nice to see someone selling cables based on their electrical properties rather than 'creative prose'!
low output capacitance buffer? szechuan Solid State 3 24th June 2011 09:21 PM
Need readily available High Voltage, Low Capacitance FET ThorstenL Parts 11 7th February 2011 11:01 AM
Low-capacitance transformer? jan.didden Parts 38 7th February 2011 08:16 AM
Has anyone tried a low input capacitance MOSFET in a line stage preamp MIKET Pass Labs 2 27th August 2003 08:29 PM
Copyright ©1999-2013 diyAudio
