Old 5th June 2012, 05:50 PM   #1
Default IMPOSSIBLE TO REMOVE HUM IN PHONO PREAMP
Friends. I built a phono preamp, based on circuits of Rod Elliott. I used good quality components and OPA2134 operational. The construction was carried out by placing the transformer pre cabinet, using a specific one for him. The interconnection notif them has been done with three wire mesh, where the mesh is connected to the network by a mass and on the other side to mass pre star. The issue is that there is always a hum auque is low. It is never silent. Post diagrams to help me that I was wrong. Greetings Jose.
Old 5th June 2012, 05:58 PM   #2
KatieandDad's Avatar
If your layout is good and your problem is not ground loop then try using heavier gauge wire for your 0V connections.
Old 5th June 2012, 06:31 PM   #3
OK. Thanks, I'll try what I advised. Greetings Jose.
Old 5th June 2012, 06:35 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Which is the AC voltage at the secondary of the trafo?. It says 7VA, but it is power. Perhaps, the voltage at the 4700 micro is few to the 78/79 to regulate (no drop out or too low), and hum goes though power lines. You need almost 12/15V, so have 20VDC at C1/C2, and personally unlike this voltage doubler. Donīt you have a 12+12V /100mA and make a Graetz bridge instead of this doubler?
LW1DSE
Old 5th June 2012, 06:39 PM   #5
sesebe is offline sesebe  Romania
With input in short-circuit the hum remain?
What is the voltage across C1 and/or C2 in power supply?
Old 5th June 2012, 06:59 PM   #6
The PSU is appauling, it is only half-wave rectified. Try a decent centre-tapped transformer correctly rated at 12-0-12V and using a full bridge rectifier.
12-0-12 will give you the required headroom for the regulators. No-one in their right mind would use a voltage doubler at this voltage.
Old 5th June 2012, 07:02 PM   #7
This is I trying to say.
LW1DSE
Old 5th June 2012, 07:11 PM   #8
I have the same type of voltage doubler in an amplifier without voltage stabilizer and I do not have any hum.
If it is well calculated a voltage stabilizer can work well.
What is the voltage on filtering capacitors from input of voltage stabilizers?
AND
With input in short-circuit the hum it is present?
Old 5th June 2012, 07:13 PM   #9
Default Modified PSU with CT transformer
Try a decent PSU.
Old 5th June 2012, 07:34 PM   #10
OK. I'm using a transformer with CT. I put a diode bridge for full wave rectification. The voltage on C1 and C2 is + - 20v. And as if you hum with the inputs shorted, not tried. I think I need to change the PCB that is not the original of Rod Elliott. PCB shipping diagram used. I appreciate your information. Jose.
Postscript: If you disconnect the wires from the in put (those coming from the turntable) only blows at max volume.
phono preamp grounding/hum long story 240zracer Analogue Source 8 24th May 2011 10:19 AM
Hum in phono pre - help please ianc13 Tubes / Valves 3 20th November 2009 10:12 AM
Hum in phono circuit Bama Slamma Solid State 2 17th March 2007 03:25 AM
hum on preamp phono output ger56 Solid State 0 31st October 2004 04:30 PM
How to remove hum sound? Kimhua Solid State 7 5th July 2003 03:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright Đ1999-2013 diyAudio
