IMPOSSIBLE TO REMOVE HUM IN PHONO PREAMP
Old 6th June 2012, 05:33 PM   #11
ALPUY is offline ALPUY  Uruguay
Thank you all. I solicionado the problem Hum. I have realized simply a ground plane on the side of the PCB welding, with a fiberglass board with copper, the same size of the PCB. welding the copper circuit ground of this plate into several symmetrical points.* Of course, supporting the fiber side of the circuit.** Now zero hum and maximum volume (in a Rotel RA-970BX) only hear at least sssssss. Please provide your feedback, Joe.
Old 6th June 2012, 05:34 PM   #12
Thank you all. I solicionado the problem Hum. I have realized simply a ground plane on the side of the PCB welding, with a fiberglass board with copper, the same size of the PCB. welding the copper circuit ground of this plate into several symmetrical points.* Of course, supporting the fiber side of the circuit.** Now zero hum and maximum volume (in a Rotel RA-970BX) only hear at least sssssss. Thanks for giving your opinions, Josť
IMPOSSIBLE TO REMOVE HUM IN PHONO PREAMPHide this!Advertise here!
phono preamp grounding/hum long story 240zracer Analogue Source 8 24th May 2011 10:19 AM
Hum in phono pre - help please ianc13 Tubes / Valves 3 20th November 2009 10:12 AM
Hum in phono circuit Bama Slamma Solid State 2 17th March 2007 03:25 AM
hum on preamp phono output ger56 Solid State 0 31st October 2004 04:30 PM
How to remove hum sound? Kimhua Solid State 7 5th July 2003 03:56 PM
