SRPP phono stage?
SRPP phono stage?
Old 5th June 2012, 06:09 PM   #11
DF96 is offline DF96  England
The 8/15 was 8 from the final 12AU7 SRPP, and 15 from the RIAA mid band 47k/3k.
Old 6th June 2012, 02:25 AM   #12
Carlp is offline Carlp  United States
@ Carlp
The last stage is essentially a line stage without a source selector, it can be omitted..
If you are seriously looking at building something check out either the Valve Itch Phono here: http://www.diyaudio.com/forums/analo...tch-phono.html
Or mine here: http://www.diyaudio.com/forums/analo...honostage.html
Either of these will run circles around the discussed design and plenty of help is available.
Thanks, Kevin. I thought the last stage was essentially a line stage, but it's weird how they only mention the phono stage in the ad - maybe their documentation is better(???). Anyway, I'm not, and hadn't been prior to this thread, thinking about building this. I was curious about the schematic b/c SRPP (which I've never heard in any form) has me intrigued.
I am very much thinking about building a tube phono stage, and have looked at the Valve Itch project. I'll also look at yours, thanks (at a quick glance yours looks very interesting but I don't understand it...yet). I started a build of Fred Nachbaur's phono stage: http://www.dogstar.dantimax.dk/tubes...cs/phono-m.gif
because I built his SE amp and loved it (it was my first electronics project). But I ran into transformer buzz and other problems and it sits unfinished in a box. Then I heard all the noise about active EQ vs passive. May never get back to it...
I am also not above a PCB project like the TubeCad Tetra or Aikido phono stages, but my first love is DIY point-to-point.
Thanks again!
Carl
SRPP phono stage?Hide this!Advertise here!
How a SRPP stage sounds like? rvrazvan Tubes / Valves 35 31st May 2011 07:55 PM
My Take on an SRPP Output Stage amc184 Digital Source 11 5th March 2010 11:20 PM
srpp input stage nhuwar Tubes / Valves 11 31st July 2007 10:03 PM
6as7 SRPP output stage Molloy Tubes / Valves 4 15th September 2006 05:39 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
