| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I have a Pioneer TX-9500II with a minor problem, the tuning meter doesn't seem to show centre frequency. With max signal read the tuning meter show offset fq. Have the SM but I stumble at ones at "output to 80dB" my signal generator only have dBm or dBuV (50Ω). Is there a way to convert dB to dBm/dBuV?
#2 |
No, there is not. dB is a relative measurement without any reference. dBm and dBuV are relative measurements with a specific reference using the dB scale
The dBm is referenced to 1mW across a 600 Ohm load, the dBuV would be referenced as dB (gain/loss) against a uV referene (in this case an RF/IF signal) dB by itself is not referenced to anything E |
#3 |
Oops. I have to correct myself. In the dark days of electronics the dB was referenced to 1.73 Volts across 500 Ohms, equalling 0.006 Watts. E
| Pioneer SA 9500II | Big_Bill | Solid State | 15 | 14th September 2009 01:15 AM |
| Pioneer TX-7800 Tuner | Serratoga | Analogue Source | 2 | 4th September 2007 04:35 AM |
| FS: Pioneer TX-8100 Tuner | pjanda1 | Swap Meet | 1 | 5th October 2005 12:03 AM |
| Pioneer TX-5A Tuner | Jack Thomas | Tubes / Valves | 3 | 6th October 2002 02:15 AM |
