| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Friends, I am to build a RIAA phono preamp. I am currently using a circuit-based pre Rod Elliott. I ordered the parts on eBay to build a SOLIDPHONO of TNT. as they say is based on the LEHMANN BLACK CUBE.
I would like your opinions on the project. step and advise me how to connect the in put, and published in the circuit in the negative input of TNT SSM2019 is connected to ground. It is so or not is connected to ground and remains balanced input?. Greetings Jose.
#2 |
Post the circuit. José.
#3 |
With inverting input grounded it is not a balanced input. If you want to use a balanced input configuration refer to the application note for input bias current path.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#4 |
I appreciate your information. Do you think of this circuit with its power supply. Is apparently based or clone of the Leheman Black Cube (expensive). José.
#5 |
I don't think the supply is particularly brilliant, I'd like to see something closer to the Sulzer/Jung super regulator..
I was not terribly impressed with the black cube when I heard one. (A/B test against a cello phono stage and one of my own)
#6 |
OK. I will investigate phono cello. José.
#7 |
Cello phono is all discrete and probably a bit difficult to duplicate, but IMO not impossible. The results will be worth it if you can pull it off.
#8 |
#9 |
OK. Try to find information and CELLO circuits. The problem is that I bought on eBay and components to build the Solidphono. But in the world of DIY audio i never finished. If I can build it. Greetings and thanks for the feedback. Joseph.
#10 |
Since you have all the parts you might as well finish it..
Some modifications to the power supply should be possible by just cutting some etches and jumpering as needed. It can serve as a reference for determining the merit of other designs and when superseded by something better you can just loan it out.
| TNT Preamble Modification | Anchan | Solid State | 7 | 16th November 2010 06:08 PM |
| TNT Solidphono PCBs | Devius | Swap Meet | 0 | 8th April 2006 11:58 PM |
| Tnt Indiscreet | diyman | Analogue Source | 0 | 26th September 2005 03:38 PM |
| tnt convertus dac | garbage | Digital Source | 19 | 26th April 2004 01:54 PM |
| DIY Solidphono RIAA circuit from TNT-audio.... | jazzpeter65 | Solid State | 5 | 28th March 2004 06:05 PM |
