OPINION ON TNT SOLIDPHONO
Old 5th June 2012, 08:47 AM   #11
On Hiatus
SY's Avatar
Originally Posted by kevinkr View Post
With inverting input grounded it is not a balanced input. If you want to use a balanced input configuration refer to the application note for input bias current path.
If the commercial circuit throws away the greatest advantage of the SSM2017 like that (balanced input with extremely high CMR), I'm not surprised that you weren't impressed. I'm using a similar circuit, though fully balanced and with THAT1646 as the output IC, for a temporary preamp while I debug my tube MM stage, and it sounds pretty darn good. NB that all wiring between arm and preamp is also balanced.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th June 2012, 04:52 PM   #12
ALPUY is offline ALPUY  Uruguay
OK. Thank you very much for your opinion. Josť.
Old 5th June 2012, 05:03 PM   #13
kevinkr's Avatar
I don't think that is the only issue with this design, but I can see why they would throw away the diff input option since very few arms support the option.
Interestingly enough I can very easily convert my SME arm, all I would have to do is change the lead out cable at the proprietary connector. Unfortunately this is not an option on the much better Schick arm I use day to day..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th June 2012, 05:23 PM   #14
On Hiatus
SY's Avatar
What else do you think is not right about the design? Output cap is sorta puny, but the rest looks pretty straightforward.
OPINION ON TNT SOLIDPHONOHide this!Advertise here!
TNT Preamble Modification Anchan Solid State 7 16th November 2010 06:08 PM
TNT Solidphono PCBs Devius Swap Meet 0 8th April 2006 11:58 PM
Tnt Indiscreet diyman Analogue Source 0 26th September 2005 03:38 PM
tnt convertus dac garbage Digital Source 19 26th April 2004 01:54 PM
DIY Solidphono RIAA circuit from TNT-audio.... jazzpeter65 Solid State 5 28th March 2004 06:05 PM
