I have a Blue Point No.2 MC cartridge. It has quite a high output of 2.5mV so it is currently connected to the MM phono input of my amp. But I would like to build an MC head-amp kit for this.
Can anyone offer any suggestions/recommendations of MC head-amp kits?
Thanks in advance.
Thanks in advance.
With 2.5mV nominal output, a head amp is likely to cause lots of problems- non-optimal load for the cartridge, input overload, overloading the RIAA stage... What exactly is the problem you're trying to solve?
If you're committed to that cartridge, you'll get the most bang for buck by optimizing the loading. The Blue Points tend to be particularly critical regarding the loading capacitance (including cables), so pay particular attention to that.
Actually, no, you don't. The whole point of high output MC carts is the output is high enough to connect directly to a MM phono input. At most you may wish to change the loading from 47k down to something like 1k or whatever is recommended by the cartridge manufacturer.
"real" MC carts have outputs down around 0.15-0.45 mV so they need an extra 20 dB of voltage gain that is provided by the head-amp, step up transformer, or a dedicated high gain phono stage.
