Linn Lingo vs. Dr. Fuß or Square-Wave vs. Sine Wave Oscillator for Motor Control - Page 6 - diyAudio
Old 21st April 2013, 03:15 PM   #51
tiefbassuebertr's Avatar
Default Turntable Motor Control Unit for Transformators for Voltage and 50 to 60Hz Conversion
What I must do to modify the schematic from post #1 (Valhalla/Lingo) in such kind, that I can drive a mains transformer for medium power between 50VA and 500 VA instead a synchronous motor?
I need it for a required 60 Hz oprating by certainly audio components for the US marked. Krell's HTS5.1 or Sunfire Theatre Grand Theatre are examples.
Various power amp models from Mark Levinson uses power amps in that kind to create a high-purity sine wave for the actually mains transformer of the amp.
Thank you for advices
Old 23rd April 2013, 01:29 AM   #52
Jaimo is offline Jaimo  Canada
I tried the following experiment with promising results several years ago but abandoned my LP12 after rebuilding my Garrard 301.
Create a 60Hz (or 50Hz depending on the pulley) .wav file using Audacity and save this to a good quality MP3 player / CD rom etc. Play the file into a preamplifier and power amplifier that is capable of driving a step up transformer. (If memory serves me right, I had wired a 12V secondary transformer as a step up device to get 80-100VAC @ 60Hz)
You can adjust the output voltage level by changing the volume and find the optimum low noise point this way. You can also compensate for speed errors by creating files that are slightly faster than 60Hz (I created a series of tracks at 60.1Hz, 60.2Hz etc)
As mentioned previously, Audacity gives one the ability to create multiple tracks and one can manually create harmonic frequencies at different levels and play these back via a second channel and mix the signals in the preamp. One could even take this concept further by creating two sine waves at pre-determined phase angles and drive the motor windings without a phase shift capacitor. (not recommended as this could fry your amplifier)
I used a Rotel RB 900bx power amp and a RC970 preamp and recall that the power amp ran very hot so more work was needed in this area - perhaps a class D amp or different step up transformer?
I destroyed my Rotel power amp (unrelated experiment!) a few years ago and can't re-run this test as a result but I would be interested to find out if this approach offers any improvements over the traditional oscillator circuit. I am willing to bet that this option is not nearly as bad as the rf hash creating Valhalla board and may be an improvement on the 'Geddon scheme since the turntable can now be fed with a cleaner supply.
Old 23rd April 2013, 06:46 PM   #53
I currently run a Berger Lahr permanent magnet synchronous motor in a similar fashion. I use 2 20:1 transformers driven by a T-amp; it was necessary to add 4 ohms of resistors to the primary(amp) sides of the transformers, as without them the amp shut down almost immediately. This is unsurprising, as without resistors, the load is nearly a dead short(very low DC resistance)!
No capacitor is needed, as two 60hz waves can be outputted as left and right channels; and the phase angle can be manipulated, which has a significant effect on operation.
I initially used Audacity, but switched to a program called Cognaxon, a two channel frequency generator, which allows better control over relative level and phase; in fact the desired phase shift can be entered numerically- believe it or not, my current shift is 90.08 degrees!
I use this directly off a laptop, as I found that moving to a .wav file and burning a CDROM gave inferior results- implying, I think, that digital conversions have phase shifts to which these motors are sensitive(and not only the motors-our ears also, I suspect).
Cognaxon doesn't save anything, so it has to be set up everytime the computer is restarted, but this is fairly quick. A volt meter is needed to set the relative levels, these can be set within about 0.3 volts.
Obviously, not a permanent set up, but it's a good experimental rig, and reasonably cheap, below $100; the largest expense is the the transformers, mine were about $35 ea. IIRC. They are instrument/control transformers for use in applications where it's required to drop 480V power to 24V for a control circuit, for example. In this application, of course, the transformers are used backwards, to step up, not down. Any electrical supply vendor can supply them.
The harmonics tricks(for which I don't think Cognaxon would help you, you would need Audacity or equivalent) I haven't gotten into, other than to confirm that adding a 3rd harmonic(180hz) to a 60hz Audacity file flattens the peak, which may be helpful. i believe Mark Kelly has had success with this, though i don't know if he uses computer files.
Currently, i just acquired a Miracord 10H(for hysteresis) motor, which turns out to be a Papst 3 phase, wired delta, so I'm thinking about how to run that of a computer file...will need another transformer, and a surround receiver...
Old 24th April 2013, 12:49 AM   #54
Wow rcthweatt ! - this is a step forward!
A few questions - are you using the laptops analog outputs directly into your T-amp? I can't see how a directly generated sine wave could be any different to a wav file play back arrangement - can you save the output of the Cognaxon software to disk?
Also, what is the power rating of the T-amp? I have a class H board that I can build along with several control transformers. I also recall using a series resistor on the amp's output to increase the load impedance.
I may want to pull out my LP12 again and try this!
Old 24th April 2013, 02:47 PM   #55
You could use maths software like Gnu Octave to generate the two phases with complete control of level, phase and 3rd harmonic content
Old 24th April 2013, 03:03 PM   #56
Yes, I connect the headphone jack to the amp input, both are mini-jacks. the amp is a cheapie from Parts Express, 10 or 15W IIRC. As the Linn motor is doubtless very similar to mine, this should be ample-I get 81-2 volts to the motor @ 1-2 o'clock on the amp volume control. The voltage balance I set in Cognaxon, I set left at 40dB, and change right to match as closely as possible-it's below 40dB, for some reason, and varies with each start-up. Another mystery is why I get better results with more gain on the computer than the amp(this was true in Audacity also)-the speaker volume in the computer I set to max.
The connections from the high side of the transformers to the motor I make at a small terminal strip, left, right, and common; I don't ground the common currently, but I'm pretty sure this would be 'code', National Electrical Code here, not sure if Canada uses this or (no doubt) a close equivalent.
Given my problems with transferring my Audacity files, I haven't tried anything with Cognaxon, just got it set-up, left it that, and went on to the next squeaking wheel(lots of those). I'm intending to try out hysteresis motors before getting back into the pm motors anyway.
I can feel no vibration whatever on the motor, there was a lot with the original capcitor set-up. Partly this is due to the fact that in the original(VPI MkIII), the motor was de-coupled from the base, which trapped, rather than drained the vibration-a stethoscope didn't pick-up motor noise on the base, but it did on the subchassis as long as the belt was on! It's now tightly coupled to the base; VPI's SAMA(stand alone motor assembly) upgrade for these tables effectively does the same thing.
Recommend experiment with miniscule changes in phase and listening -it sounds nuts that 0.01 degree could matter, but it's easy to do.
Old 24th April 2013, 04:27 PM   #57
Thanks for the suggestion-though I confess I don't know when I'll be able to devote the time it would take me, anyway, to really exploit a program like that..it would be very helpful to have a set-up like the controller at the top of this thread with that kind of adjustability-since every motor is different, and very small changes are audible. Being able to enter numbers, versus turning a pot, makes experimenting a lot faster and easier.
Old 26th April 2013, 12:04 PM   #58
Default Power Amp topology for driving mains torodial transformer
No informations?
I start in this case this thread:
AC converter vrom 220V/50Hz to 110V/60Hz for Krell HTS-5.1 or Sunfire Theatre Grand
Old 26th April 2013, 01:01 PM   #59
At 60 Hz at up to 500VA you want a class D amplifier (and remember that capacitor filterl power supplies draw very high current peaks)
Old 15th December 2013, 09:44 AM   #60
Default Linn Valhalla Replacement from Hercules
Who have heard this parts?
Class A - Hifi servicing
Wanted: HP 209A Sine/Square Wave Oscillator scott17 Swap Meet 0 15th March 2012 02:58 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Sine and square wave function generator Bricolo Parts 14 7th March 2003 11:45 PM
Copyright ©1999-2017 diyAudio
