diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Empire 698 Tonearm Replacement (http://www.diyaudio.com/forums/analogue-source/212493-empire-698-tonearm-replacement.html)
Clontarf 11th May 2012 06:29 PM
I'm looking for an Empire 698 tonearm. Mine has succumbed to a fairly common fault of this arm; disintegration of the plastic connector at the headshell end of the arm. It is the part that the headshell slides onto. If anyone knows of the whereabouts of one of these, it would be most helpful. Also, anyone knowing of a way to convert this arm to a more common mount, or to repair the mount on this one, would help as well. Can the arm wand be swapped? Is there a replacement arm that would with the Empire electronic lift? Have I asked enough questions?:whacko:
harwoodspark 12th May 2012 07:28 AM
2 Attachment(s)
A Notts Analogue arm can be made to fit with a little effort. The geometry is correct for this turntable and it sounds so much better than the Empire offering. Modification involves machining the arm pillar down to fit the hole in the Empire subchassis.
Bgymnastics 25th September 2016 04:04 AM
Witch one and how much do they cost?
harwoodspark 31st October 2016 06:09 PM
The arm in the two pics is an Omega Point One. This was Tom Fletcher's first arm I believe and I still have it. I doubt I'll ever part with it. My Empire 598 now has a Notts Analogue Mentor tonearm fitted which is basically an upgrade from the Point One and looks similar to an Ace Space. You should be able to pick one up for 300 quid, maybe a bit less if you're lucky.
Copyright 1999-2017 diyAudio
