Belt driven Synchronous Motor vs. DC Motor for Record Players - diyAudio
Old 11th May 2012, 11:34 AM   #1
tiefbassuebertr's Avatar
Default Belt driven Synchronous Motor vs. DC Motor for Record Players
Most user say, the best kind of motor for this aim is a DC motor.
Are there also a benefit for the synchronous motor in opposide to a DC motor?
Thanks for advices.
some URLs for both kind of motors:
Papst DC Motor
"GS 38.09" oder "VDC-3-43.10" (937 4310 602)
DC-Motor - VDC-3-43.10 B00 von ebm-papst
http://img.ebmpapst.com/products/dat...B01-615582.pdf
und unter posting 24 unter
Papst Motor VDC-3-43.10 - Phono - Restaurierung und Selbstbau - Analog-Forum
Mclennan Synchronmotor MV86111
Motors
http://www.mclennan.co.uk/datasheets...0411131813.pdf
http://www.mclennan.co.uk/datasheets...vdatasheet.pdf
Dr. Fuss Motornetzteil - Frank-Landmesser.de
Old 11th May 2012, 02:16 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
My father has an old Winco turntable, and uses asychronous AC motor, and still works pretty fine, including the strobo test.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 11th May 2012, 02:26 PM   #3
SoundBound's Avatar
I would say that AC or DC motor is not the defining parameter, once a good motor is chosen, it is a matter of how the speed of that motor is controlled.
DC motors can be quite good but they do require a very well designed controller to maintain the speed and prevent issues with speed drifting.
AC motors have been used for quite a long time and in some very high end quality turntables. They rely on the consistency of the AC waveform driving them (usually the AC frequency of your line supply).
I am going the way of AC motors, as they are in my favourite Thorens, Linn and Ariston turntables. I am currently building a controller project for AC sync motors. If you are interested in my thoughts about them, you can check it out at my blog.
Audio This 'n Audio That
SoundBound
Old 11th May 2012, 03:02 PM   #4
Send a message via MSN to sq225917 Send a message via Skype™ to sq225917
I would take a low voltage AC motor, 24v, and a controller from Daniel (user name Meldano) and run it lightly loaded in the deck using either viscous damping or an eddy brake to smooth out an vestiges of cogging.
Paradise Pre-reg PSU PCBs
Old 12th September 2013, 12:21 PM   #5
Default Lingo vs. RADICAL
are there any news concerning listening tests?
Who have heard Linn's last upgrade "RADICAL" against Lingo at the LP12 ??
see pics here:
Radical.....the inards
similar to this - so I think:
Motorsteuerung für Masselaufwerke
Old 12th September 2013, 12:59 PM   #6
Similar, well they are both DC motors- but that's it. The Linn uses a Maxon motor, the Pabst motor is a far more complicated animal altogether with hall sensors on the rotors. The Linn set-up is just a simple optical tachofeedback with a very slow feedback loop on top of a current sensing feedback arrangement.
The Linn radikal speed stability isn't that good. No better than a Lingo, but the motor is lower in mechanical noise.
Old 12th September 2013, 03:17 PM   #7
Thank you for this advice.go also to Linn LP12 motor malaise ?
Thanks for advices.
go also to
Papst DC Motor
Motors
To this topic there is since a long time this already existing thread:
DC vs AC motors - a newbie needs help
Old 21st September 2013, 10:34 PM   #8
kevinkr's Avatar
Berndt please repost with your comments outside of the quote. We all have these moments. Thanks.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st September 2013, 10:37 PM   #9
berndt is offline berndt  United States
SoundBound
Hi, any progress on the ac sync controller?
Have a few decks using papst motors and want to build a speed controller, thanks.
Old 21st September 2013, 10:46 PM   #10
diyAudio Member RIP
Synchronous is simpler for simple mains AC frequency derived
single speed stability and DC is simpler for variable speed/pitch.
Proper drive of simple DC motors is a subject much obfuscated.
rgds, sreten.
DC motor control for belt drive Giordano Analogue Source 5 8th February 2012 07:39 PM
Help required for choosing an AC sync motor for a belt driven turntable. binspaul Analogue Source 58 20th May 2010 06:38 PM
Cutting vibrations from a (Garrard) synchronous motor. Triumph Analogue Source 34 29th January 2009 10:13 PM
Belt driven Motor placement and belt properties luvdunhill Analogue Source 2 16th July 2008 06:21 PM
AC PSU for synchronous motor jo-briggs Analogue Source 11 22nd May 2005 07:08 AM
Copyright ©1999-2017 diyAudio
