Another diy MM RIAA - diyAudio
Old 5th May 2012, 09:00 PM   #1
Default Another diy MM RIAA
I've designed and build a MM RIAA preamplifier that has a good dynamic and detailed sound. The noise is very low. Although I am very pleased with it, I would like to hear if anyone has ideas on how it can be improved.
I have built several of this preamp, as several of my friends want one, because they were not satisfied with the RIAA preamps they had.
Old 7th May 2012, 10:49 PM   #2
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
that's a lot of capacitance with all those paralleled, non-cascoded 2sk170 jfets.
not a good thing for a moving magnet cartridge interface.
also, the source degeneration resistors are quite large - not great for low noise.
mlloyd1
Old 8th May 2012, 03:16 AM   #3
Chris Hornbeck's Avatar
Noise, not counting excess noise, in a MM RIAA stage if realistically including a MM cartridge is dominated by the combination of the inductive (and resonant in the upper audio band) cartridge source impedance and the 47K load resistor.
Designs optimized for a short circuit source impedance are mistaken, and often compromise other goals. As mlloyd1 posts above, the heroic efforts to get the device noise equivalent down to a couple dozen Ohms is then thrown away with 300 Ohms of degeneration. Why?
But the 325 Ohm equivalent device noise + 47 Ohm input filter + 150 Ohm feedback resistor is *still* unimportant because noise is determined elsewhere.
Sounds like a lot of criticism, but is intended constructively. Took me a while to figure out why my system noise factors were so wrong.
All good fortune,
Chris
Old 8th May 2012, 05:00 PM   #4
Thank you for your feedback. The first version i made, did not have the parallel-coupled jfets. The noise was remarkable higher. I think i will try make a complete other design.
Ultrasimple mm/mc RIAA preamp 2 Mad_K Analogue Source 340 28th June 2016 10:26 PM
Simple MM only RIAA preamp x-pro Analogue Source 60 1st November 2013 11:17 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 08:42 PM
Onix MM Riaa board nknhifi Solid State 0 29th May 2007 08:27 PM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 07:34 PM
Copyright 1999-2017 diyAudio
