SUT earth lift implementation Q - Page 3 - diyAudio
Old 8th May 2012, 12:33 PM   #21
batty is offline batty  Australia
Bling bits for my RB250 Rock DL-103
Townshend Rock II, My new TT since 1986.
Old 8th May 2012, 12:45 PM   #22
It seems Roy was right about 8Hz , I certainly beleive it . The RIAA point is that some pre amps have a 20 Hz filter in built . I speculate that raising the resonant point might help lift the bass a bit . If owning turntables unlike the Rock which has a damper , there is a considerable lift in bass at resonance . Personally I find it useful as the cutting engineer has to limit bass . Could be why LP's always sound preferable to most CD . Tube amps do it also if SE I find . What the Rock has is the ideal use of a damper . I suspect using thinner damper oils helps ?
If using the 12 Hz rule some pick ups of the 1970's ( Sonus Blue , ADC ) required arm mass of - 5 g ( impossible ) .
In reality in an SME or Infinity Black widow they were fine at 8Hz . The Cu on some was 60 . Tracking was possible at 0.7 g .
Old 8th May 2012, 11:41 PM   #23
Yes, thinner fluid in my trough also I use J7s slippery stuff for the bearing which is thinner than the supplied oil.
I found the DL-103 works really well with the front end damping added to the RB250.
SUT cct batty Analogue Source 4 19th April 2011 10:22 AM
SUT enclosure help CrimsonKink Construction Tips 0 11th March 2010 03:05 AM
Wiring this as SUT pjanda1 Analog Line Level 3 14th May 2008 02:58 PM
Motorized projector lift (scissor lift?) JRace Everything Else 5 7th January 2008 04:11 AM
how do I lift/not lift earth frank2395 Pass Labs 30 31st May 2005 08:38 AM
Copyright 1999-2017 diyAudio
