Strain Gauge jFET Pre-amp
Old 18th December 2012, 06:25 AM   #11
andyr is offline andyr  Australia
Originally Posted by hazard500 View Post
pass band is 10 hz to 150 kHz +/- 0.2kB. You can really hear 0.2dB drop at 150kHz?
I would say no! I had thought the "pass band" meant the -3dB frequencies, not the 0.2dB frequencies.
BTW, the spec sheet shows a 0.4dB loss at the mid-band. Does this imply the loss is different at different frequencies? The reason I am interested is that I can save a bundle if I can use LL1527s instead of output coupling caps, to stop DC passing, in my phono stage. I have been using $350 a pair caps!
One point, though ... the spec sheet specifies some particular input & output impedances - source 800ohms , load 4Kohms. This seems to me to not be comparable to the real-world situation which a phono stage is in ... eg. a phono stage feeds a line-stage preamp ... which is likely to have a Zin of 10-50Kohms?
Andy
Old 20th December 2012, 02:21 AM   #12
hazard500 is online now hazard500  Australia
Andy
Andy, I have always assumed that the 0.4dB loass at mid band implies a constant loss across al freq due the DC resistance of the TX. IE if you had a perfect 1:1 tx then the gain is 1, but real world losses mean that this tx has a gain of -0.4dB at mid band. Then the pass band is referenced to this point, ie Lundahl quote 20hz to 150kHz +/- 0.2dB referenced to the mid band.
In answer to your question about replacing caps with the Lundahl LL1527 - I would not do this if your amp is single ended. If you look at my circuit you will see that it has a balanced output so there is NO DC passing through the tx. If you have a single end output, and connect the tx between output and ground, there will be a DC voltage across the tx and hence a DC current - not a great outcome.
If your line stage has a Zin of 50k, then you can provide the 4k load for the tx by putting a resistor across the output of the tx - that's the way I do it. 4K resistor would be OK, this will give a total resistance of 3.7k. As long as the output of your phono stage is 1k or less then you will have no problems (as longs as its balanced!!)
Old 20th December 2012, 06:59 AM   #13
Thanks for this additional info, mate. Yes, my phono stage is single-ended, not balanced. I obviously had it wrong - I thought it was possible to use a series coupling transformer as an alternative to a series coupling cap, to stop DC offset passing though.
Oh well, I'll have to go back to using expensive 1uF caps!
Andy
Old 18th September 2015, 10:51 PM   #14
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
150kHz is not high enough? What source are you listening to, even if its 192kHz then there's nothing above 96kHz.
Oh, I just checked the spec sheet - pass band is 10 hz to 150 kHz +/- 0.2kB. You can really hear 0.2dB drop at 150kHz?
I have found that over complicating a circuit with many components to try and get an absolutely flat frequency response when not much correction was needed, often does more harm than good. So I agree with your point
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 20th September 2015, 08:06 PM   #15
hottattoo is offline hottattoo  United States
Smile strain gauge jfet pre-amp
Hazard500.
I would look up Dave Slagle and ask him about things strain gauge. I know he has been working with various cartridges along with pre-amps / transformers Try Intact audio and Amia ( Dave's site ). Good luck.
Old 20th September 2015, 08:54 PM   #16
Default strain gauge jfet pre-amp
Correction, Dave's site is Emia. Sorry for the wrong spelling of his site.
Old 14th April 2016, 10:47 AM   #17
I've been happily living with my strain gaugue amp from post #1 for a couple of years, but have some time off work recently and time to play around. Key things that have been bugging me
1. The original circuit is lacking some gain.
2. The circuit is single-end in, differential out. I'm a tidy person and want everything to be differential all the way (my power amp is also differential).
So I have rebuilt the strain gauge amplifier as per attached diagram. Key changes are:
a. grounded source fet (2SK369) has been converted into a complementary feedback pair with the addition of a pnp transistor (BC560). I tested this and measured 1,800x gain with an input of 5mV!! Source resistors have been added to bring down gain to a sensible level.
b. Strain gauge is sandwiched between equal resistors to provide a differential output across the strain gauge. There will be DC at each end of the SG so capacitors are required to couple the differential output to the long tail pair.
c. The coupling caps are actually an advantage. It is claimed that strain gauge cartridges don't need eq as the natural 6dB roll off is reasonably close to the RIAA curve. However, below 50Hz the RIAA curve is flat. The 6dB roll off below 50Hz afforded by the cap (3.18uF with 1Meg), together with the 6dB increase below 50Hz of the strain gauge, provides a flat response below 50Hz as required by RIAA curve.
4. RCA connectors on the input of the pre-amp have been replaced by 3.5mm TRS connectors.
So how does it sound? The biggest change is the way that the circuit handles surface noise. Previously, the pre-amp emphasised high freq surface noise and older records could sound almost hissy. Now, the differential input seems to cancel surface noise - crackles and pops are still evident if the record is less than perfectly clear but the hiss of surface noise that starts as soon as the needle hits the groove, has gone. Frequency extension both up and down is excellent. The coupling caps look quite small but as described above, the value is correct and there is no lack of bass. While surface hiss has gone, this is not at the expense of high frequency response, which is at least as good as it was. Probably better.
So I am very happy with upgrade, and the changes are in too stay.
Note: As before.
1 Output is coupled to power amp via Lundahl 1527XL transformer.
2 There is no pre-amp, only a source switch box. Volume control is effected by 24 position switched resistors across the output (so this is a true gain control, not an attenuator).
Old 25th April 2016, 01:36 AM   #18
ppap64 is offline ppap64  Canada
Hi
Have been planning to build your original design (post #1) ever since seeing it over on Vinyl Engine. It was more appealing than Flavio's opamp design because it had a lot in common with the fet-based opamps inside my active crossover.
You commented at the time that the gain was just enough for your Win, so for my Panny SG, I was going to reluctantly add SU transformers, so it's cool that the new version has increased gain. But I bought BL Toshibas at the time so am wondering if they're ok to use instead of GR's, or are there some value changes needed.
Appreciate you sharing your efforts for others who also want to max the performance of their quirky but amazing strain gauge cartridges.
Old 25th April 2016, 09:41 AM   #19
Hi, 2SK369 BL will work fine - no adjustments required. Just match Vgs at 1mA.
I also recommend that you match Vbe in the pnp transistors at 4mA. They control the current through the jfet via drain resistor (650 ohms). So matching Vbe will keep the current at 1mA in both jfets..
Also, you can adjust gain with the source resistors. 5ohm gives heaps of gain with the Win (much more gain than I had with the original circuit, with no degeneration). It may be enough gain for the panasonic. But if not you can reduce to 2 or 3 ohms if you need even more gain.
I've been playing lots of records in the last week, and really enjoying the new gain stage. Hope you enjoy it as well.
Old 24th October 2016, 06:00 PM   #20
jam is offline jam  United States
jam's Avatar
Hazard,
What gain are you getting with the posted (latest) schematic unloaded?
Strain Gauge jFET Pre-ampHide this!Advertise here!
JFET guitar Pre-amp JammyBStard Instruments and Amps 33 18th April 2018 11:25 PM
Sound Smith Strain Gauge Phono Preamp Johnloudb Analogue Source 24 17th December 2017 05:43 PM
JFET Phono Pre-amp clipping JammyBStard Solid State 6 26th November 2011 06:42 PM
Strain gauge cart weight/compliance? ro9397 Analogue Source 0 5th March 2009 10:50 PM
Strain Gauge pickups woody Analogue Source 2 10th April 2004 02:48 PM
