diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Rega RB200 Tonearm wiring help needed (http://www.diyaudio.com/forums/analogue-source/210215-rega-rb200-tonearm-wiring-help.html)
Chas78 5th April 2012 10:48 PM
I am trying to repair the wiring on a Rega RB200 tonearm, the rubber 'L' shaped connector that attaches to the bottom of the arm has come off and there are 6 wires that need to be soldered, they are blue, white, ground x2?, red and green. But what is confusing me is that there are two black wires (ground) so do I solder both to the ground on the 5 pin 'L' shaped connector? I was only expecting one ground wire.
Any help or advice would be great!
wrankin 11th April 2012 03:24 PM
Here:
http://www.diyaudio.com/forums/analo...ring-help.html
Hope this helps,
-bill
Resources saved on this page: MySQL 18.75%
