Rega Turntable Base board - diyAudio
Old 20th March 2012, 08:45 AM   #1
Smile Rega Turntable Base board
Hi, Can anyone tell me the following about on the Rega turntables
1) how thick is the base board
2) how far is the center of the spindle from the L/H side
3) how is the center of the spindle from the front
Thanks Derek
tabarddn
Old 22nd March 2012, 12:01 AM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default why?
trying to make a cosmetic clone of one. There are better tables to emulate if that's the case.
There are those that have made new plinths for rega turntables. Do a search, I'm sure someone who has done will would be willing to help out.
stew -"A sane man in an insane world appears insane."
Old 11th April 2012, 05:10 PM   #3
wrankin is offline wrankin  United States
Umm, *which* Rega?
On my older Planar2 the plinth is about 1 inch thick. The spindle is about 6-5/8 inches from the left edge and about 7-1/8 inches from the front edge.
If you are building a replacement base, then the thickness can be taken by measuring the thread height on the bearing. The other two measurements don't really matter that much, although you should probably make it long enough to where the platter doesn't overhang.
More important is the spindle to arm pivot distance, which is specific to the tone arm. For Rega arms, it should be 222mm.
Hope this helps,
-bill
Bill Rankin
Looking to Buy - Rega Planar 2 Turntable FEET dtm1962 Swap Meet 0 6th December 2011 07:04 PM
Rega Planar 2 turntable Mungo Park Analogue Source 9 5th December 2011 02:25 AM
Rega 3 turntable info needed Derek Cohen Analogue Source 6 8th October 2010 09:21 PM
Custom Acrylic turntable. Rega. mattjk Swap Meet 1 20th December 2006 11:16 PM
FS: Rega P3/2000 turntable Saurav Swap Meet 1 13th October 2004 12:01 AM
Copyright 1999-2017 diyAudio
