Cary ph301 schematic anyone?
Old 19th March 2012, 04:05 PM   #1
woodturner-fran is offline woodturner-fran  Ireland
Default Cary ph301 schematic anyone?
It's a long shot (seeing as searches throw up zilch) but would anyone have a schematic or service info for a cary ph301. It's an all valve mm/mc unit with 2 x 12au7 2 x 12ax7 and a 5814a as an output buffer. I'm particularly looking for operating points, voltages etc.
Alternatively, could someone point me towards a similar schematic? Searches haven't thrown up much.
Also, can a 5814a be a substitute for a 12au7?
Any info most appreciated!
Fran
Old 19th March 2012, 04:34 PM   #2
kevinkr's Avatar
Yes, the 5814 can sub for the 12AU7A. Try contacting Cary directly - they may or may not be willing to provide you with a schematic and service information.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th March 2012, 05:06 PM   #3
Thanks Kevin,
I already emailed them but didn't hear back yet. I thought there might be a chance seeing as it's long gone from their product line....
Fran
Old 19th March 2012, 09:47 PM   #4
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Cary seems to be holding their cards extremely tight. Two of my brothers drive Carys ( and the third one McIntosh...). One of the Carys haveing been causing him some trouble, and we've both been searching for quite some time.
I'll be following this closely....if you succeed, please let me know.....?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 19th March 2012, 10:16 PM   #5
Will do......
When I got this in for repair (and hey, since when did I become a repair man? - since friends found out I could scrape through a repair!) there was a tantalum cap on the heater supply burnt out. The 12V reg for the heaters was also dead. So I replaced the cap and the reg and she all powered up OK.
A couple of the resistors in the power supply also were gone - probably as a result of the others going, and I replaced those with my best guess at voltages etc.
So I have it connected and powered up and it actually sounds good!! Within 20 mins though, another of the tantalum caps gave out in an interesting puff of pink smoke!! Now I think these really don't like AC at all, so I reckon there is insufficient filtering on the DC heater supply (bridge rectifier into 2200uF cap, then on to a metal can 7812), probably could set up a little filter there easily enough.
I can probably get it running without Cary's help, but it would be nice to be sure. I'm going to replace all the electrolytics (some of them bulging a bit) and the tants with electrolytics. I reckon they used the tants (10uf) just because the build is tight enough and it made life easy. Small low impedance 16V electrolytics are cheap enough it seems.
Fran
Old 20th March 2012, 07:01 PM   #6
So cary came to me. They can release the schematic once I pay them 35usd....
Fran
Cary ph301 schematic anyone?Hide this!Advertise here!
Cary 845 schematics soulmerchant Tubes / Valves 15 9th April 2013 03:24 PM
Cary slp-70 nelsondog Tubes / Valves 2 11th October 2011 05:50 AM
Need schematic Cary Audio SLP-70 preamp coolmaster Tubes / Valves 0 19th January 2007 03:05 PM
Cary Audio V12 - Schematic - Needed Yukonsc Tubes / Valves 1 26th December 2006 06:03 PM
Cary cd300 with HDCD pengxy Digital Source 0 19th November 2004 03:15 AM
Copyright ©1999-2017 diyAudio
