| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
My integrated amp uses 4x NE5534N in the RIAA cct. has anyone tried using discrete op amps such as the Burson or Audio GD Earth/Moon/Sun as a direct drop in replacement?
Townshend Rock II, My new TT since 1986. |
#2 |
I'll take that as a 'no' then.
#3 |
wombat
Some possible reasons for the silence: the NE5534N is not that awful to begin with and/or other IC's like the AD745 may well be a better choice than the discrete opamps. ymmv and others will disagree.
#4 |
Thanks Grufti. The integrated in question is a Copland CSA14 so not shabby to start with.
#5 |
I would not change them. The 5534 is still one of the best devices around for this type of application. Better to spend your efforts on building something.
#6 |
Dear Batty,
I changed in my deeply modified Luxman L-210 (yes, you can move this small amp to high-end ) the IC opamp to Burson's dual Opamp as well. Now this part of the Luxman is true high end as well ! However you have to take care that the Burson is embedded in the right electronic environment. This seems to be also in this Forum not always being realized and therefore Burson's potentials is not really exploited. Acc. manufacturers information the Burson Single and Dual Opamp shall be operated between 12-25 V and min 19mA, but Burson informed me ideal supply is at 50 mA. In my Luxman I changed therefore in the phonostage (all caps already changed to top-end quality elko, films and micas) the zenerdiodes for stabilized voltage supply from 18V to 22V (higher voltage is normally better for sound ) and more important changing the resistor from 2,7K to 330ohm to increase current supply to ~ 50 mA. I also checked with ~ 30mA but with ~ 50mA 3-D image further improved. Generally the sound is fantastic, smooth "tube-like" trebles, new details from vinyl, you do not want to finish listening...breathtaking. A real IC killer but you must adjust the electronics around to take full advantage. ~ € 65,- for one dual opamp is then the cheapest highend investment ever !(I want to underline that f.e. such a Luxman session powering a Precide Kithara LS I have for A/B comparison f.e. my Airtight STM-1, STudio Monitors and other gadgets... )Cheers Goetz
Goetz
| op-amp + op-amp buffer combinations | eccdbb | Chip Amps | 2 | 22nd July 2011 04:13 AM |
| Precision op-amp RIAA pre.. | Dxvideo | Analogue Source | 8 | 27th November 2010 08:19 PM |
| Favorite op-amps for RIAA preamp? | Conrad Hoffman | Parts | 37 | 8th November 2008 11:49 PM |
| riaa lcr new stevens & billington eq600 and Silk 10k | alboran | Vendor's Bazaar | 3 | 20th November 2007 03:56 PM |
| Sell or Swap Thorens TD-165 & Kenwood KD500 turntables (B.C.) (and other stuff) | dangus | Swap Meet | 11 | 22nd October 2007 04:40 AM |
