Old 22nd February 2012, 01:54 PM   #1
Default Michell platter diameter
Hi
I am working on a new platter to my Michell Gyrodec bearing.
I would like to drive i with the original Mirchell motor, so I would like to know if anybody can tell me the exact diameter of an Michell Orbe platter or an Gyrodec platter, where the belt drives the platter...
Thanks in advance.
Peter
Old 23rd February 2012, 01:14 AM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default all you need to know
is the speed (RPM) of the motor, and the frequency of your domestic supply (North America is 115 VAC, 60 Hz...). Then measure the belt pulley on the motor accurately. Then measure the diameter of the platter or sub-platter at the location of the "driven" portion of the platter or sub-platter as is the case. If you have a 60 Hz motor, it is most usually a 300 RPM type. The ratio of the motor speed to platter speed is the drive ratio. If a 300 RPM motor, and the platter spins at 33-1/3 RPM, then the ratio is as follows:
300: 33-1/3
300:100/3
900:100
9:1
so for every 9 turns of the motor, 1 turn of the platter occurs. Now look at the diameter of the pulleys and do a ratio of those. Say the motor pulley has a diameter of 11 mm Then:
9 (revs of the motor) × 11 mm= 1 (rev of the platter) × diameter of the "driven portion of the platter or sub-platter. In this case the diameter of the driven portion of the platter is 99 mm. This little bit of math does not take into consideration any possible belt stretch which should be. But dimensions and material of the belt should be known.
What type of motor is the motor an AC (early) or a DC (late) one?
stew -"A sane man in an insane world appears insane."
Michell Gyrodec QC supply esl57 Analogue Source 0 24th April 2011 10:00 PM
JA Michell Syncro TT dwk123 Swap Meet 2 1st April 2010 02:58 AM
need Teres platter diameter directdriver Analogue Source 10 21st July 2009 08:59 PM
My new Analog Rig - Michell Tecnodec Algar_emi Analogue Source 17 10th September 2008 09:07 PM
Michell DC motor type nige Analogue Source 7 6th December 2003 02:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
