Old 10th February 2012, 02:25 AM   #1
Default Please point me to a mic pre project
Looking for a 1- or 2-channel mic pre with +48dB avaliable as a kit.
Old 10th February 2012, 05:08 AM   #2
Always a good place to start - and maybe end.
Low Noise Balanced Microphone Preamp
He has other preamps but I use one similar to this and it works very well with my AKG condenser mics.
Old 11th February 2012, 12:44 AM   #3
Looks like an awesome project, thanks!
Old 11th February 2012, 04:23 AM   #4
Found this That 1512 based kit: Dantimax (elektronik) - Preamps_-_poweramps Anyone have an idea of how it compares to the Elliot circuit?
Old 11th February 2012, 08:59 AM   #5
My guess is it may be quieter and better balanced unless you select the resistors and transistors on the Elliot circuit. I've been thinking of replacing my preamp (now 29 years old) with something like the Dantimax.
Old 11th February 2012, 11:27 PM   #6
Do you mean the Elliot kit can perform better with something different than the specified 2N4403 and BC549? Maybe a LT1351 would be an improvement over TL071? Basically I'm trying to determine which project would be a cleaner pre. The mics I plan to use are a pair of small diaphragm condensers initially, down the line some DIY electrets and dynamic mics. I'll be using Canare or Mogami starquad to connect to my PC interface. What AKGs do you have BTW? Cheers!
Old 12th February 2012, 07:43 AM   #7
No, just matching the components in the front end, not just using the first 2 out of the bag. And yes, many opamps are better than the TL071.
The Dantimax is likely better and doesn't require any selection as the IC was computer trimmed during manufacture of the chip.
My AKGs are C451EBs with CK22 cardioid capsules. I use Canare and Neumann cables.
You might want to add hard limiting to the preamp output so as not to damage the PC input in the event of severe overload. The PC wants less than 5 Vp-p while the preamp can put out 25.
Old 12th February 2012, 10:14 AM   #8
SY's Avatar
THAT1512 (or SSM2019) works really well- the Dantimax kit is probably a good option. I would also check the next issue of Linear Audio for Scott Wurcer's mike pre; we used it for some recordings here and it's outstandingly quiet.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th February 2012, 09:14 PM   #9
You might check out Paul J. Stamler's Jensen transformer input class A design. It was originally published in Recording magazine and is available free of charge at www.recordingmag.com. Look for "The Solid-State Mic Preamp".
I have read good things about designs based upon the Burr-Brown preamplifier chips (INA163 and INA217) and those by THAT (1510/1512). Go to the Texas Instruments and THAT Corporation sites and check their application notes for those parts.
If you are very adventuresome, look for Paul J. Stamler's tube mic pre design, published in audioXpress as "Big Mike and the Jimmy" in the February/March/April 2002 issues.
Take a look also at the designs at www.fivefishstudios.com. They offer complete kits in various configurations.
Old 13th February 2012, 10:37 AM   #10
Those look like nice mics. I love the hard limiter idea!
Originally Posted by SY View Post
Originally Posted by majerjack View Post
Thank, guys. I have no skills in circuit and board design but Scott Wurcer's circuits caught my interest. Is this it? Linear Audio | your tech audio resource Would it be compareable to the Elliot and Dantimax projects in terms of simplicity and parts cost?
$5 mic pre rockstudio Instruments and Amps 11 12th March 2007 06:39 PM
Mic pre transformers Tim Wyatt Tubes / Valves 2 25th June 2006 11:00 PM
mic pre amp help psychosteve Solid State 0 12th February 2006 09:15 PM
mic + pre a007udio Multi-Way 3 10th February 2005 02:27 PM
manley mic pre ben goh Tubes / Valves 2 10th September 2002 01:40 PM
Page generated in 0.12035 seconds (82.50% PHP - 17.50% MySQL) with 10 queries
