Old 9th February 2012, 11:14 AM   #1
suds is offline suds  India
Default 4 Channel Selector with LCD, Push Buttons
Hello,
I have made a 4 channel audio selector with Amplifier Power Switch using icro controller (89C51) there are three modules,
1.Controller module with connectors for front panel
2. Front Panel Module with LCD,Buttons, LED.
3. Audio Selector Board with relay, uses 4 pole relay to independently switch audio channels and ground (common ground return not used).
Controller module will have memory, last selected channel will be saved, next time when its switched on.
Additional feature Amplifier Power On/Off control using micro push button on panel (will drive 35A Relay).
Will post the schematic and images once work is completed.
~suds~
Old 16th February 2012, 09:43 AM   #2
Posting completed PCB artwork, firmware will be ready on next 7 to 10 days
Modular circuits , it can be used in combination with other circuits.
Control Board (micro controller board)
Uses 89C51, heart of circuit has connector for push buttons, LCD, ports to connect other modules, Power supply on/of .
Front Panel
Push buttons and 3 led's connected to control board(third one connected to 5vdc)
4 channel Relay Board, 4 pole relay to switch Left,Right and ground.
Common return ground is not used, additional mute relay (used during power on/off , and channel change) separate ground connection from amp for mute.
Relay board can be used with other circuits also, 5VDC relay are driven by ULN2003
Prototype likely to be ready during first week of march.
PCB Gerber files will made available for download. (with out firmware)
Images Below:
~suds~
Push-Pull using only N-Channel MOSFETs Kashmire Solid State 32 6th August 2009 01:48 PM
Push Buttons? samsagaz Parts 1 26th December 2008 03:17 PM
Push Buttons Jitterbug Digital Source 0 14th February 2007 05:43 AM
Assemblage D2D Push Buttons fmak Digital Source 0 22nd April 2005 09:38 AM
Sourcing caps for push-buttons Fragen Parts 3 30th October 2004 03:24 AM
Page generated in 0.07467 seconds (68.86% PHP - 31.14% MySQL) with 11 queries
