Old 27th January 2012, 12:37 AM   #1
Default Technics SL1200 MK2!
Hello,
I have the weirdest problem, I own 2 pairs of technics, one pair of 1200 mk2 and one pair of 1210 m3d, both purchased recently used but in good condition. Here's the problem, both pairs drift out of time severely. This was confirmed by recording a record into cubase, obviously i wasnt expecting digital accuracy but within 8 bars it had lost the metronome pretty badly! The other 1210 was slightly more stable but still a concern. I've been a dj for 20 years and have never found technics to be this problematic to mix on so I'm kinda thinking whats wrong with these turntables. Replaced the pitch controls in the 1200's recently (all callibrated properly), didnt help at all so tried levelling them, still no help. The only common denominators between the turntables are the cartridges and styli which i swap around as and when, the records I play and the electric supply in my house. I'm using shure m44-7 cartridges. Any help/suggestions would be gratefully received.
Cheers
Old 27th January 2012, 02:20 AM   #2
kevinahcc20's Avatar
I have a 35 year old SL1500 that was drifting slowly in speed...replaced all of electrolytic caps in the power supply & it snapped right in.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 27th January 2012, 09:23 AM   #3
Hi kevin, thanks for the reply and info, do you know if there is a way of testing the caps? It's odd because if you look at the strobe it appears to be keeping good time but they are a nightmare to use. Any other issues with these turntables that can cause these symptoms?
Cheers
Old 27th January 2012, 09:57 AM   #4
Based on your description i would also vouch for Kevin's idea.
Change the caps with Panasonic FM or FC.
Old 27th January 2012, 01:10 PM   #5
Cheers
In my case the strobe was the evidence of speed instability. The speed would not lock into a stable relationship on the strobe and it would slowly drift with no way to stabilize it using the speed adjustment pot. If you are showing "lock" on the strobe while seeing drift based on digital acquisition of the music then it seems there are three possibilities:
-The frequency of your AC supply is unstable...this seems very improbable as the interconnected grid enforces lock step and in my experience (looking at a high resolution HP counter) it stays very close to 60.00 Hz.
-The degree of frequency stability you need is much higher than the resolution of the strobe display or you have the speed adjusted to one of the alternate strobe dot displays for higher or lower pitch rather than the "big dots" for standard pitch.
-The album you are working with was recorded with a speed error...no idea how likely this is.
Old 29th January 2012, 01:25 AM   #6
Thanks for the replies! Update: Been carefully analysing the strobes and it seems that on one of the 1210's the strobe is showing a very slight pulse on the platters dots, the dots seem to slow down (or speed up, not sure which) momentarily before continuing their journey, this was confirmed on all rows of dots. Also, I cant make the dots on any of the tables stand stationary at all, they're always either going slightly backward or forward but never stationary unless quartz lock is activated. So......new caps all round?
Old 29th January 2012, 01:29 AM   #7
I would go with caps 1st as they are cheap and easy.
Old 29th January 2012, 01:45 AM   #8
Ok cheers, any caps in particular or just all of em?
Old 29th January 2012, 01:59 AM   #9
If you are going to disassemble just do all of the electrolytics - it should cost you about $5 for parts...the film and mica cas are good to go so leave them be.
No Power Technics 1200 Mk2 lukeysim Power Supplies 0 27th March 2011 01:56 PM
Technics 1220 mk2 pitch control problem akt91493 Analogue Source 5 28th June 2010 12:29 PM
Improved PSU for Technics SL1210 MK2 and SP 10 MK2 (and others) beetle Analogue Source 21 19th January 2010 11:25 PM
Technics SL1200 / 1210 Speed Fluctuation Problem rob110101010001 Analogue Source 1 31st May 2008 03:52 AM
Technics 1210 MK2 Expertise wanted sikniks Analogue Source 17 6th July 2006 02:59 PM
Page generated in 0.09785 seconds (83.20% PHP - 16.80% MySQL) with 10 queries
