Old 21st January 2012, 08:07 PM   #21
I soldered the wire to the missing pins, put the chip in the socket, and it works fine, therefore I don't really need a new IC.
In the near future I will remove the IC socket, as recommended, and solder the IC chip direct to the PC board. There is plenty of working room. What is the advantage of doing a direct solder vs. using the IC socket?
Old 21st January 2012, 08:11 PM   #22
Juergen Knoop's Avatar
no, leave it as it is!
Old 21st January 2012, 08:21 PM   #23
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Leave it !!
I just looked at the schematic for the MR77, and it is certainly not MC 1309 or 1310. Your early tipper may be right about it being an MC or LM1303, as the pin configs seem to match.....
The schematic lists it with Mc part numbers only, so I'm not totally sure.
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 21st January 2012, 09:03 PM   #24
The reason to install an IC in socket is the easy replacement. If you solder it to the board you must have some knowledge on how to remove it or you may destroyed the board. In the way I fix a problem like yours is used an old IC cut the pin flush to the body and slide in under the piece of the leg left and solder it.
Old 22nd January 2012, 06:53 AM   #25
Mooly's Avatar
Pleased it's working.
Sockets can be a source of trouble, and with a different profile of wire than intended (the broken pins)... well lets just say it's not ideal although it may never give a problem in practice.
If you want to experiment with braid removing parts then practice on some scrap item, an old remote or something.
A simulation free zone. Design it, build it, test it.
Old 24th January 2012, 08:47 PM   #26
Good job.
The LM1303 used to be made by everybody, but now it's so old even NTE has discontinued it. The LM1303 is a clone of the UA739 and here is a thread on finding a replacement.
Ray
ua739 Op Amp Replacement
Old 10th February 2012, 06:26 AM   #27
I forgot to thank everyone for your help. It was a simple un-invasive fix. Tuner sounds wonderfully clear after a good cleaning of all the contacts.
All the best!
FM IC in Mcintosh MX113 tuner-pre ampliton Everything Else 2 12th August 2010 11:09 AM
McIntosh chassis help needed FranStar Tubes / Valves 1 22nd October 2006 10:53 PM
Mcintosh MR65 Tube Tuner tongkk Tubes / Valves 0 10th March 2006 02:59 PM
Knobs for McIntosh C26 preamplifier and MR74 tuner MOER Swap Meet 0 5th October 2003 03:42 PM
Help needed with McIntosh MC2500 diyman Solid State 3 27th February 2002 06:23 PM
Page generated in 0.07175 seconds (84.04% PHP - 15.96% MySQL) with 11 queries
