Regulators in Parallel
Old 19th September 2003, 01:10 PM   #1
Marvellous is offline Marvellous  South Africa
Marvellous's Avatar
Default Regulators in Parallel
Is it possible to use regulators in parallel
to increase output current ?
or will this not work?
"When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minuteóand itís longer than any hour. Thatís relativity." - Albert E
Old 19th September 2003, 01:12 PM   #2
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
I dun think that will work...coz one regulator will tend to take all the current...and just shut itself down...letting the other take over...and then shutting it down as well...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 19th September 2003, 01:17 PM   #3
Bricolo is offline Bricolo  France
Bricolo's Avatar
you'll have to place a small resistor (0.1 to 2R) between each IC's output and the global output
Old 19th September 2003, 01:28 PM   #4
Marvellous's Avatar
So this will WORK
Will I still get 12V output?
Old 19th September 2003, 01:32 PM   #5
li_gangyi's Avatar
Possibily...you might want to try tweaking the resistor value to get faster better response...I would try 1ohm first...
Old 19th September 2003, 01:51 PM   #6
Marvellous's Avatar
Thanks everybody for the help!
I'm going to try this now!
Old 19th September 2003, 02:00 PM   #7
li_gangyi's Avatar
By the way...that theory by Albert on relativity was pretty cool....
Old 19th September 2003, 02:00 PM   #8
Vigier is offline Vigier  Netherlands
Heeej Marvellous,
make sure (if you're going to use 1 Ohm resistors, which i DON'T recommend) that these resistors can dissipate enough...
Grtz, Joris
Old 19th September 2003, 02:04 PM   #9
li_gangyi's Avatar
I would definetly reccomend a pass transistor if he wants BIG currents...
Old 19th September 2003, 02:14 PM   #10
You MUST use that series resistor or you'll see your 7812's burn one by one, but I would use something between 0.1 and 0.2 Ohm, that should do the job.
Grtz, joris
Regulators in ParallelHide this!Advertise here!
parallel voltage regulators to increase current? troystg Solid State 22 4th September 2015 08:05 AM
+/- with pos and neg regulators vs 2 pos regulators mr.duck Power Supplies 8 12th October 2006 05:27 AM
LM317 and LM337 Regulators in parallel jlm Solid State 7 7th January 2006 09:08 PM
LM317 and LM337 Regulators in parallel jlm Power Supplies 2 7th January 2006 09:50 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 08:12 PM
