Regulators in Parallel - Page 2 - diyAudio
Old 19th September 2003, 02:31 PM   #11
Electrons are yellow and more is better!
peranders's Avatar
Can you switch to 7812 instead of 78L12?
You can probably connect them brutally in parallel because they have current limitation but they are not indestructable. If you add resistors they will probably share current better but if they don't misbehave without resitors, don't use them.
Switch to 7812 seems to be a better solution if that's possible.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 19th September 2003, 02:37 PM   #12
JOE DIRT®'s Avatar
ummmmm...the series resistor goes on the input
the 78 series regulators have built in current limiting so the resitors on the input act as a current sharing load
and I reccomend a pass transistor also
Old 19th September 2003, 02:48 PM   #13
Bricolo is offline Bricolo  France
Bricolo's Avatar
I would recommand a bigger reg rather than a pass transistor. Easier to implement
Old 19th September 2003, 02:49 PM   #14
jackinnj's Avatar
a pass transistor is cheaper and you don't have to worry about one regulator hogging the current. In fact, you can get a linear regulator to oscillate even without trying. (Nat Semi does have an application note showing the LM317 as a switching regulator!)
In talking to one of the customer service techs at Nat Semi they did indicate that some customers used some of their Simple Switcher Regulators "stacked", but they did not recommend it.
Old 19th September 2003, 03:01 PM   #15
Marvellous's Avatar
Default Pass transistor it is
Then Pass Transistor is is!
I thought that maybe this would be a simple quick Solution!
Thanks AnyWay Everybody
"When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minute—and it’s longer than any hour. That’s relativity." - Albert E
parallel voltage regulators to increase current? troystg Solid State 22 4th September 2015 08:05 AM
+/- with pos and neg regulators vs 2 pos regulators mr.duck Power Supplies 8 12th October 2006 05:27 AM
LM317 and LM337 Regulators in parallel jlm Solid State 7 7th January 2006 09:08 PM
LM317 and LM337 Regulators in parallel jlm Power Supplies 2 7th January 2006 09:50 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 08:12 PM
Copyright ©1999-2017 diyAudio
