Old 11th January 2012, 09:17 PM   #1
Default Linn Keel
Hi everyone,
I am thinking on un upgrade my lp12 with a new keel. I am thinking on manufacture one.
Question: do anyone know if tech. Data (drawings, specs, etc) is available for a Diy project?
K.Rgds
Old 12th January 2012, 12:57 AM   #2
andyr is offline andyr  Australia
Originally Posted by Inortega View Post
Hi everyone,
K.Rgds
We have a saying in English (I'm assuming English is not your first language! ) "If pigs could fly ...".
Why do you think Linn would publish their IP just so any DIYer could copy the Keel?
If you really want to make one, you can get the external dimensions from your current pressed-steel subchassis and armboard. The final shape can be different - eg. more ovoid.
If you make sure you cut out sections of an aluminium billet so that:
1. the total weight is similar to (or at least, not too much more than) the pressed-steel subchassis & armboard, and
2. the centre of gravity is at the same point as the pressed-steel subchassis & armboard
... you might get something that approximates a Keel. However, unless it is made of the same aluminium alloy as the Keel, it won't perform exactly the same. Then again, Greenstreet makes a Keel-clone, so why not buy theirs if you can't afford a genuine Keel?
Another alternative - which is the path I have chosen - is AudioFlat's "RubiKon" ... which is rated (by Linn dealers) as 90% of the performance, for 1/2 the price! (In my case, the choice was driven by the fact that they will make one for a Graham 2.2 arm, which the Keel is not available for.)
Andy
Old 1st April 2012, 10:19 AM   #3
Andy
Andy,
Thanks for info.
K. Rgds
Need help on LINN armboard NickBRN Analogue Source 21 15th July 2007 08:20 AM
Linn Tonearm Panicos K Swap Meet 5 9th October 2006 01:12 AM
linn volume tobyclem Chip Amps 0 9th August 2006 11:13 AM
Linn Valhalla 6072a Analogue Source 5 15th October 2005 02:01 PM
Page generated in 0.09359 seconds (77.58% PHP - 22.42% MySQL) with 10 queries
