| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#21 | |
The Audio Amateur had several articles over the years about modding the DH-101. Mine was pretty darned quiet and dynamic by the time I was done with it. It gave my Sumo Electra preamp (purchased many years later) a run for its money. I lent the DH-101 out a few years ago and haven't seen it since. |
#22 | |
The 4/1980 issue of TAA -- had some RIAA recommendations: Q1 and Q2 -- use current gain matched units, change R10,R11 to 47R -- Hafler provided a kit for this purpose. RIAA -- change C5 to 940uF, R9 to 90.9k -- change C7 to 0.024uF and add a 0.068uF from phono out to ground to reduce the rising HF response. Coupling capacitors -- C2,8,11,20 -- were all bypassed with film caps. It was also suggested that a 50K 10-turn pot replace R6/8 so that DC offset on the phono stage be eliminated. In any event you'll have to adjust either R6 or R8 to minimize DC offset. Obviously, the power supply issues aforementioned need addressing. |
#23 | |
#24 |
We might also want to consider replacing the power supply diodes (D1-D4) with soft recovery units, and/or install a snubber across the transformer secondary connections on PC-1. Replace C24-C27 with low-ESR versions of the same values and bypass each one with the largest polypropylene cap you can fit under the circuit board. Film caps to replace the cheap disc caps at C13 & C14.
Or just rip out PC-1 and replace it with a pair of Sulzer Op-Amp regulators (also featured in The Audio Amateur) and call it a day.
#25 |
I think you might be surprised by how good the Linear Tech regulators sound in comparison to the Sulzer.
#26 | |
But seriously, I would hope that someone's come out with decent regulators for audio applications after 20+ years of R&D. I pulled up the specs on the LT1963A and I'm not finding the output impedance anywhere. It's an important spec and is one place where the Sulzer shined.
#27 |
I think the Sulzer was TAA/1980 -- and it is quite a good regulator -- I have one with the "pre-regulator" and a bit beefier pass transistor.
#28 |
I have them regulating the power to the front end of some of my amps. With a separate (much smaller) transformer I just leave the front end "On" all the time and power up the outputs when it's time to listen. No warm up time, as the outputs thermally stabilize pretty quickly.
| Hafler DH-101 Preamp | torens147 | Solid State | 12 | 22nd May 2012 10:29 PM |
| Preamplifier Power Supply Rail Capacitance, How Much? - DH-101 vs DH-110 | Ron AKA | Power Supplies | 3 | 17th November 2011 02:15 AM |
| Hafler DH-101 parts f/s | Johnny2Bad | Swap Meet | 4 | 10th April 2011 12:22 AM |
| Help - noisy phono stage | ianc13 | Tubes / Valves | 11 | 8th July 2009 05:18 PM |
| DH 101 Line stage/PS upgrade kit on Ebay | ddanbo | Solid State | 0 | 28th October 2008 07:07 PM |
| Page generated in 0.11305 seconds (79.97% PHP - 20.03% MySQL) with 11 queries |
