| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
The idler wheel of my Thorens TD124 MKII (ser#83443) isn't properly engaging the stepped pulley at any of the speeds. As I've tried to show in the drawing, the idler wheel contacts too high
![]() I've checked both the owner manual and service manual, but find no mention of any idler wheel/pulley alignment. I only have one thin nylon washer below the idler wheel and I don't think I should run it without any washers at all. The manual shows both felt and nylon shims beneath it. Thanks for any advice. |
#2 |
Verify that nothing is stuck/sticking in the speed stepping mechanism, and idler arm, and make sure that the cam that sets the pulley height is fully seated with washer, and c-clip in place.
You can raise the intermediate pulley slightly by loosening the lock nut and turning the set screw slightly clockwise to raise the intermediate pulley.
www.kta-hifi.net |
#3 |
Thank you for your reply. I've tried to loosen the lock nut, and it doesn't budge. I sure don't want to apply too much torque and end up breaking it! I have no access here in the tropics to penetrating oil. In envy people who can just walk down to the nearest hardware store (I suppose that nowadays in the U.S. I should say drive over to the nearest Home Depot).
i'm not sure where to locate the "the cam that sets the pulley height ... with washer, and c-clip". |
| Thorens TD124 with SME3012 | Curling3 | Swap Meet | 0 | 18th July 2011 05:40 PM |
| IDLER WHEEL DESIGN-Just the idler... | kozzmo99 | Analogue Source | 8 | 7th September 2009 06:41 PM |
| marantz cd 42 pulley wheel drive | totaltony2000 | Forum Problems | 0 | 29th March 2009 10:00 PM |
| Thorens TD160 MkII armlift problem | ddutch | Analogue Source | 3 | 29th September 2007 12:44 PM |
| Teragaki designed Epson-Seiko Sigma series of idler wheel turntables | amsci99 | Analogue Source | 1 | 4th January 2007 08:22 AM |
| Page generated in 0.06550 seconds (73.49% PHP - 26.51% MySQL) with 10 queries |
