beginner help - thorens td 125 mk2
Old 3rd January 2012, 07:33 AM   #31
langers2004 is offline langers2004  United Kingdom
Thanks that is a HUGE amount of info :-)
The motor is not spinning! But when i plug the unit in and turn it on i do get an orange light which is most visible with the top plate removed.
The motor spindle and the turntable section all spin freely and the rod from the table is still covered in lube if i remove it entirely.
So im assuming that there is something wrong with the control section of the table. I will investigate today and post some pics :-)
thanks again
Old 4th January 2012, 06:29 PM   #32
Ok photos to follow shortly but this is an update.
Apparently the cone needs replacing? What is this? Could a 3a fuse be too small for the plug?
Old 4th January 2012, 06:35 PM   #33
Old 4th January 2012, 07:00 PM   #34
grufti is offline grufti  United States
grufti's Avatar
Mine is indeed a TD126 Mk II. Five/six ... who cares! I'm the original owner and I've had it so long that I had forgotten what it is called.
Originally Posted by flavio81 View Post
That's the TD126 or the TD145, not the TD125. The 125 is fully manual.
The electronics on the 125 / 125MKII are essential to the turntable. Nothing to be bypassed.
Old 5th January 2012, 12:59 AM   #35
kevinkr's Avatar
The 3A fuse is plenty large enough and provides redundant protection in the event of a short somewhere after the plug and before the internal fuse..
What cone (?) are you referring to?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th January 2012, 07:22 AM   #36
Ok. Im not too sure, i previous owner mentioned that when you turn it on something is meant to rise a little. This was the cone he was referring to?? He could be wrong though im guessing.
Old 6th January 2012, 04:53 PM   #37
kevinkr's Avatar
I have no clue what he was referring to..
When the motor is running the shaft may rise slightly due to the magnetic field inside the motor, but this is certainly less than 1mm and is largely irrelevant except to the mech E who designed the drive.
You will need to trouble shoot the various sections of the drive electronics or find someone who can help you.
Old 6th January 2012, 05:04 PM   #38
i think i will need to find someone to assist me then. I cant find any obvious problems.
Old 8th January 2012, 09:42 PM   #39
duderduderini is offline duderduderini  Australia
Default I reckon its the transistors
Hi
go here
TD125 MKII circuitry
Have a look at the parts list in .xls format.
I have had a 125 for many years and it stopped working twice.. it was the transistors (T1 to T4) I replaced them and the unit fired up. They are not expensive.
Good luck
"Better to say nothing and keep them guessing than to speak and remove all doubt."
beginner help - thorens td 125 mk2Hide this!Advertise here!
FS: SME armboard from my Thorens TD 125 mk2 johnnyk9 Swap Meet 1 8th December 2011 04:06 AM
Beginner Help: Thorens TD 125 voltage chrisnewton Analogue Source 3 15th September 2010 03:32 AM
cartridge for thorens td-125 maxpou Analogue Source 9 20th January 2010 01:06 AM
Thorens TD 125 with SME 3012 Karrry Everything Else 14 30th April 2009 02:58 PM
Thorens TD-125 Ken(Toronto) Analogue Source 3 31st March 2008 09:41 AM
