| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#61 |
I work with a lot of different woods and all have different resonance signatures. Bamboo is very dense and has a ring to it compaired to less dense woods. When you tap it bamboo rings rather than a low frequency thud.
#62 |
...but so does any dense material as does aluminum and brass...but just because the material rings when tapped with a nukel does that mean it will be a poorer choice than a plastic one...I think not...the impact energy of a nukel ring is many thousand times more higher than a acoustic or cartridge energy can induce into it...its a matter of obsorbtion or reflection of energy when it comes to a cartridge and how it reacts with record, mat or no mat and platter not even mentioning the mechanics of the bearing interface with the rest of the turntable will be more of a factor than density of platter...the higher the density and mass the better in my opinion...dimension of material used is just as important
#63 | |
Wood Densities John |
| JVC l-e88b turntable - platter won't spin | jlbriggs | Analogue Source | 0 | 1st January 2011 04:44 PM |
| Turntable platter from plaster | magentawhale | Analogue Source | 24 | 31st August 2008 02:47 AM |
| Project One Turntable Platter Problem | SigloOne | Analogue Source | 4 | 5th March 2008 01:39 AM |
| turntable platter impedance matching | zeliboba01 | Analogue Source | 2 | 23rd August 2006 06:55 PM |
| Platter mat for TD124 turntable. | ashok | Analogue Source | 3 | 19th March 2004 02:20 PM |
| Page generated in 0.08522 seconds (66.35% PHP - 33.65% MySQL) with 11 queries |
