motor and circuit for diy turntable project
Old 24th January 2013, 05:38 PM   #31
krandle37 is offline krandle37  United States
Hi Stuart, The platter and bearing look like a substantial build. From where did you acquire and how much did it cost?
Old 19th February 2013, 08:38 AM   #32
Stuartarm is offline Stuartarm  Canada
Default I purchased two green flywheel papst motors from ebay for possible use in a diy turnt
[QUOTE=Nanook;2841076]I've looked at this for quite a while now, and have even designed a complete turntable suitable as a belt, rim or idler drive. The motor system could be either AC or DC.
There are pluses and minuses to everything, but each type of motor system can have their own issues. I agree that the Mark Kelly/Sylvain Bergeron DC controller PCB makes a lot of sense if DC is what you are after. I think there is the ability to compensate for increased temperature and load. I'll have to re-read the documentation.
For AC synchronous speed controls the issue is getting to the correct frequency to drive the motor at the correct speed. This entails the use of high precision oscillator (thankfully readily available), some sort of filter to keep noise to a minimum, and the inclusion of an amplifier circuit to get to an appropriate voltage AND/OR the use of a phasing capacitor . If using only a phasing capacitor you rely on the AC mains frequency (and hope the frequency of your mains is dead on 50Hz or 60Hz, whatever the case may be). So initially the AC motor/capacitor system can get you started.
The phasing capacitors for a particular speed to be maintained are motor specific (well more correctly the number of poles) and are usually provided by the motor manufacturers. Also you must determine the AC voltage you want to run at. For example Hurst (and I am not neccessarily recommending them) has a 24VAC and a 115 VAC motor that is essentially identical, but require different phasing capacitor. AFAIK dropping the voltage increases torque so there is some appeal to that option. But a much larger capacitor (or group of capacitors) is required and are not included with the 24 VAC version motor.
Regardless of which motor type and what the designed RPM for the motor is, drive pulleys are required (or spindle extensions, etc) and some means of either altering the frequency (for AC drives) and/or the voltage required (mainly for DC types, but altering the voltage for AC motors can get you to a "sweet spot" where mechanical noise is reduced to a minimum, while still maintaining the ability to drive the platter as per the requirements for a Premotec motor as used in the Linn LP12.
This is not meant to create an new thread, there are enough here and various other sites that discuss/argue the merits of AC vs DC motors and their use in turntables.
Hope this helps and doesn't add to the confusion ...[I purchased two green flywheel papst motors from ebay for possible use in a diy turntable project. I know nothing of them and got little info from the seller but the price was right...highest bidder at 16.50 cdn...I am looking to get a power supply/speed control for them...I will try to attach pics for these (original from ebay)...Motor numbers are as follows: KLO 14.50-2-420D followed by a triangle symbol...second line reads as follows: 7cha Nr 7882-064...what type of motor is this AC or DC?..could these possibly be 3 phase?...no indicaton of voltage, frequency etc...any info or help would be appreciated.
Attached Thumbnails/QUOTE]
Old 19th February 2013, 04:27 PM   #33
Nanook is offline Nanook  Canada
Nanook's Avatar
Default 2 green Pabst motors.
Stuartarm : any information? The platter and bearing look pretty nice (better than anything I could manage). I imagine a massive deck. If you have the ebay posting number (whether completed or not) then a link would get us there
To me this is almost a false economy (in design not financial). I understand the desire for a large heavy platter, but the need for one can easily be minimized or disregarded if multiple motors are used.Personally any platter in the 7-12 lbs. range should suffice if the drive system, bearing and materials are upto the task.
If a heavy-"ish" platter is to be used then geometry of the platter needs to be addressed (this is a subject that many folks don't consider). The shape can be as important (or even more so) as the mass of the platter.
stew -"A sane man in an insane world appears insane."
Old 21st February 2013, 08:26 AM   #34
...not actually sure what you mean nanook...this platter is only 1/2 inch thicker than many high end platters out there...yes i agree there is more to designing turntable platters than size...bearing set up is also crucial and if you look at finished product on the bearing it could easily do without a plinth its so massive...but will do one anyway when i get the foot design absolutely right...regardless i am not going to stop until this is perfected being it overkill or not it is what i desire...this project is the biggest i have ever embraced
Old 21st February 2013, 08:40 AM   #35
was a custom build bearing and platter assembly i designed so it was double their own platter...1200 cdn delivered...just so u know they also use same bearing concept after my submitted design to sell an upgraded platter for rega turntables..Choir Audio
Old 21st February 2013, 01:29 PM   #36
nigel pearson is offline nigel pearson  United Kingdom
7lbs is fine . The Garrard 401 is a good example of design . The motor is more powerful than average ( using about 24VA ) . The drive coupling is more ridged via the idler drive . The motor is a hysteresis type which shows no pole jumps if rotated by hand . The bearing length is about twice that of many and thicker . The rumble from the bearing alone is better than - 80 dB weighted .
I had a bronze platter made for a 301 . The sound was ponderous . Eventually it was scooped out and worked well .
The best improvement to a 301/401 was a very low distortion power supply .
Old 21st February 2013, 02:25 PM   #37
Nanook's Avatar
19th February 2013 10:27 AM
stuartarm: 1/2" thickness increase for a solid platter is a huge amount of mass being added. I didn't see the underside of the platter, but am assuming it is a solid disk of material. If not machined out, then a lot of energy is wasted and contributes little to the flywheel effect vs energy applied.There are a couple of ways to get to the same result. Multiple motors vs. massive platter is one. The key is to conserve momentum.
Feet have been designed in so many iterations that somewhere feet must exist. If wanting to do something strictly custom because you can, that's OK. However unless you have some fairly sophisticated measuring equipment it is unlikely you will improve on existing designs.
I look forward to seeing the end result.
Old 21st February 2013, 04:02 PM   #38
bear is offline bear
expert in tautology
bear's Avatar
Why would a low distortion power supply have any effect at all on a system that is essentially a giant mechanical LP filter??
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 22nd February 2013, 08:11 AM   #39
_-_-
If you use a very elastic belt a low distortion power supply will be of little importance . Some now use linen or tape recorder leader as a connection . If so a quality once described as dynamic wow is reduced . This is probably caused by the varying load on the stylus point . Secondary effect is vibration through the structure which is much over estimated . If the motor is of the typical synchronous/stepper/DC type ( notched ) then the usefulness of a low distortion supply is less . From that it is critical to infer that the motor is very important .
The Birth of the Garrard 501
If you take the direct coupled system of a Garrard it resembles the Bumble bee . The Bumble bee should not be able to fly . Equally the Garrard should be an impossible concept . Certainly cheaper turntables can out do it's OK rumble figures ( - 57 dB typical ) . The first thing noticed using a low distortion power supply is that the motor has less vibration . Guess what , the rumble figures are now - 79 dB ( that's where I got after 15 years with the Garrard 501 ) . What will surprise most people is very little of the 401 was changed . I retained the platter mass .
My point is this . The ARX turntable was developed to make a cheap transcription turntable possible . It is not an ideal starting point . I would say it is a near perfect example of what it set out to do . The Garrard 301/401 , Technics SP10 and to a lesser extent Thorens TD124 were the true transcription turntables . They are difficult to clone .
If I were building a high grade turntable from scratch I would use the Technics 1210 motor run at high speed . It would have the stiffest connection I could get . The platter and bearings I see used here seem fine . It has no need for a special power supply . People do play with how it's servos work . The flywheel concept of turntables is baffling . It should be critical , it seems merely helpful . On the other hand bearing design ( not quality so much as long as it is fit for purpose ) is totally critical .
Old 26th February 2013, 10:46 AM   #40
More reading if not already seen .
BELT DRIVE TURNTABLE Philips Thorens Verdier Melco Micro Mercure NOTES DIY
motor and circuit for diy turntable projectHide this!Advertise here!
Improving a turntable (motor controller circuit) ;) sek Analogue Source 27 5th March 2016 09:11 PM
Oracle motor/controller problems - DIY turntable g-horn Analogue Source 26 12th January 2013 11:50 PM
Turntable AC motor - optimizing the circuit dobbykins Analogue Source 2 8th July 2011 02:12 AM
diy Turntable - AC Motor Control Rick H Analogue Source 7 19th June 2011 04:07 PM
Turntable project completed but need motor assistance. Vinyl-Addict Analogue Source 25 21st April 2007 04:11 PM
