motor and circuit for diy turntable project
Old 27th March 2013, 11:47 AM   #91
msdin is offline msdin  United Kingdom
Berger Lahr stepper motors these may be better than the Rapid Electronics motor.
http://download.schneider-electric.c...1150300579.pdf
Old 27th March 2013, 01:59 PM   #92
nigel pearson is offline nigel pearson  United Kingdom
I choose the Rapid one as it looked so much like the expensive Airpax in terms of size and power ( Philips etc , Older Linn and Rega ) . The most interesting point is the generic nature of all and the fundamental limitations ( distrotion ) . Did anyone try a motor with smaller stepping angle at 50/60 Hz ?
Old 28th March 2013, 02:36 PM   #93
This type of drive has often been used for synchronous motors . It is under biased class B . Linn Valhalla and Thoren's TD125 come to mind . I have often wondered about this so decided to give it a try . I doubt it took 20 minutes to do ( no PCB ) .
The distortion is not too bad at all . It has extended harmonics right up to 1 kHz due to the notching . Some of what is seen would be less with a low distortion oscillator . The circuit is exactly as shown . It should run quite well from a NE5532 as oscillator .
The 10 uf somewhat surprisingly is hopeless . It suggests a different value would be better .
As an addition to a Quadrature oscillator it might be better than many would think ( 4 transistors ) . The un-heatsinked transistors were not even warm .
Old 28th March 2013, 05:35 PM   #94
The drive board for the Phonosophie No.3 uses a Quadrature oscillator with a zener agc which then feeds 2 H-bridge amplifiers to supply the 2 motor windings. The transistors in the H-bridge are TO92 packages.
Old 29th March 2013, 05:05 AM   #95
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
For this sort of circuit (and synchronous motors) is there a way t determine the required value of the series capacitor to get 90deg phase shift at frequency F? I know the DC resistance of the coil is a factor, but I assume the effective impedance of the motor winding at F, based on its DCR and its inductance, would both effect the required capacitance to achieve 90deg phase shift.
I ask about this because I am installing an older Thorens 16-pole motor intoa anothe Thorens turntable, which has a different value cap than I expected. Is there a formua whereby I can guesstimate the right value of C, without access to a 'scope?
Thanks. (and sorry for the hijack)
Old 29th March 2013, 09:52 AM   #96
I tried to work out the phase shift . The reality says trial and error is best . My reverse engineering solution suggests when voltages are equal it is likely to be approximately correct . As you can see when phase 2 ( orange ) is so distorted as in my last example , it is anyone's guess what " roughly equal " is . Vibration and torque ( finger test ) says plenty , better when the motor is off of the turntable ( be careful if high voltage ) .
Looking back , the TDA 2040 and transformer solution roughly agreed . The class B/C buffer via 10 uF produced a very distorted wave and noticeable reduction in torque . If there ever was an argument for negative feedback this might be it . The brown phase is OK , a bridge circuit seems practical ( 90 degrees bridge , a T bridge almost ) . The idea here is to build something cheap which is much better than average . If possible built on strip-board . No voltage dangers and no real need for an oscilloscope . The class B/C is about 9 dB better than a cheap transformer solution so not dismissed at this stage . Class B/C is noted for toughness / stability . The main focus is that the cheap transformer has considerable squaring of the sine wave . Even if a high grade transformer the mains is often at - 25 dB distortion . That means one starts at best at - 15 to - 25 dB . I did prove the motor to be a major source of distortion . None the less it seems a shame to make it worse .
I had difficulty making a buffered quadrature oscillator work . The idea of a sort of H bridge might work . One problem I had was that the BD135/6 buffer is working in current drive . The input wave looks nasty to the buffer . That wouldn't be the best thing to pass forward to the cosine stage ( the output although notched would be better ) . Using an LM324 might be the answer as that allows very simple buffering ( buffered buffer ) . The LM 324 was said in a forum to be hopeless even at 60 Hz , I was pleasantly surprised how OK it was ( the maths says it should be ) . The other solution is to add simple biasing of 2 x 10 K and 2 x 1N4148 ( 1N40001- 7 ) per buffer . That might allow reasonable performance without instability . Feeding that forward would be OK . The 2 x 10 K can be played with to have better distortion or cool running . NE 5532 for it's ability to provide current and cheapness would be prime . It has a bad reputation for being fussy so LM324 might be better . 5532 might also raise a few more volts ? If I can get the dam thing to fly I will post . Dream would be 5532 in quadrature , 2 x B/C buffer , loop feedback with 47R feed-forward resistor/capacitor ( usually 47 R ) .
Old 29th March 2013, 05:44 PM   #97
My beginners luck seems to have dried up with a simple oscillator . This is a very nice ready made design ( PCB files provided ) . That and 2 x TDA 2030 should be ideal . The perfect circle trace looks very promising .
http://www.piclist.com/images/www/ho...eagle38_03.gif
http://www.piclist.com/images/www/ho.../e_eagle38.htm
Old 31st March 2013, 10:06 AM   #98
MiiB is offline MiiB  Denmark
Would it make any sense to revert to current drive..??
Old 31st March 2013, 01:00 PM   #99
The Thorens TD125 shows how to do the job . I object to the class B/C output stage as I feel a power op amp will do a better job ( TDA 2030 ) .
I had very good initial results with the National Semiconductors circuit . I have adapted here to show TDA 2030 . As yet I have not got it to work properly as drawn . It should be close to working I feel . In H bridge TDA 2030 usually has a Zobel circuit between outputs ( perhaps 4R7 + 0.1 uF ) . In this T bridge I think it should still work ? The output would directly drive the motor with no additional components bar a power supply . Brown to sine and orange to cosine , yellow and black to 0V .
Old 6th April 2013, 02:21 AM   #100
tabarddn is offline tabarddn  New Zealand
Default DIY platter and Bearing
Hi, have been talking to TemaadAudio about their new range of DIY platters and bearing. Bearing with 10mm spindle is around $85 and apparently is the same bearing they use in their $3500 ref T/T.
A 35mm Platter is $188 and they will make any platter up to 100mm thick to special order. They also have an interesting conceipt of using 2 platter with isolation spikes placed between them. Not sure weather to go for a straight 70mm platter or 2 x 35mm platters with isolation spikes.
tabarddn
motor and circuit for diy turntable projectHide this!Advertise here!
Improving a turntable (motor controller circuit) ;) sek Analogue Source 27 5th March 2016 09:11 PM
Oracle motor/controller problems - DIY turntable g-horn Analogue Source 26 12th January 2013 11:50 PM
Turntable AC motor - optimizing the circuit dobbykins Analogue Source 2 8th July 2011 02:12 AM
diy Turntable - AC Motor Control Rick H Analogue Source 7 19th June 2011 04:07 PM
Turntable project completed but need motor assistance. Vinyl-Addict Analogue Source 25 21st April 2007 04:11 PM
