| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi
I am using VPI MW19 Mk4 and want to DIY a speed control similar to the VPI SDS for it, can anyone recommend a schematic or DIY kit? |
#2 | |
It might work in your application to vary speed. . Cheers / Chris Last edited by Chris Daly; 28th December 2011 at 05:42 AM. |
#3 |
Thanks Chris for your prompt response. It seems tht I can use the principle of an DC/AC invertor for speed control.
#4 |
I search the web using all the possible wording and can't find any similar schematic, isn't there any DIYer think about this?
#5 |
From time to time there are kits offered on eBay that might be suitable.
For good speed stability a crystal clock is usually used and divided down using programmable binary counters, subsequently this signal is run through a flip flop to assure the duty cycle is correct, (50%) and then LPF filtered to make a reasonably clean sine wave which is used to drive a power amplifier and step up transformer. You can also do it with a weinbridge oscillator and power amplifier. Have a look at the old TD-125 design for possible inspiration.
www.kta-hifi.net |
#6 |
Hi bigpandahk
Linn Products provided some very good TT speed control circuit boards. There is a schematic here ( after registration ) : Linn Valhalla Owners Manual, Service Manual, Schematics, Free Download | Vinyl EngineComments suggest its an older schematic than the image shows, but might be a good start. Not much variation on speed either but Linn instead provided a pulley system for 45rpm. Linn can be contacted http://www.linn.co.uk/support. Cheers / Chris Last edited by Chris Daly; 1st January 2012 at 07:25 AM. |
#7 |
Thanks Kevinkr and Chris, Happy new year!!!
| Hurst Motor and speed control | kolledog | Swap Meet | 3 | 13th June 2011 11:50 PM |
| DC motor speed control | winggo | Analogue Source | 13 | 25th August 2008 01:48 AM |
| TT - Speed control for Maxon 226764 | space-cake | Analogue Source | 3 | 30th September 2006 02:11 AM |
| DIY TT: motor, motor PS, platter speed measurements | dice45 | Analogue Source | 52 | 9th May 2006 01:07 PM |
| Asking help for tt motor speed unstable | chanharvey | Analogue Source | 1 | 21st September 2005 06:15 AM |
| Page generated in 0.08574 seconds (81.08% PHP - 18.92% MySQL) with 11 queries |
