Ground problem Rega RP1
Old 14th December 2011, 04:43 PM   #1
Brouilly is offline Brouilly  United Kingdom
Brouilly's Avatar
Default Ground problem Rega RP1
I have just finished a PP EL84 amp, with most connections there is no hum at all at full power - dead silent with my CD player. But with my RP-1 there is quite a bit of hum, and increasingly more when I move the arm closer to the centre of the deck.
There is no ground wire, I believe the ground goes down the tone arm in the RP-1. So I am not too sure what might be the issue. Like I mentioned the hum gets louder as the arm moves closer to the centre, maybe because of the motor.
Any tips?
Cheers
Charlie
Broke solderer with delusions of grandeur
Old 15th December 2011, 08:21 AM   #2
Groove T is offline Groove T  Switzerland
Groove T's Avatar
It is the motor.
Use another Pickup which is lesser sensible for strayfields or live with the hum.
Old 15th December 2011, 04:52 PM   #3
wrankin is offline wrankin  United States
Perchance are you using a Grado cartridge? It's a known issue. Search for "grado hum rega" and you'll get the background.
It's not an absolute problem - I have an old Planar-2 with a newer RB250 and a Grado Blue and the hum is almost non-existent. But I also run the motor at a lower voltage than standard.
-bill
Bill Rankin
Old 16th December 2011, 03:10 PM   #4
Brouilly's Avatar
Will look into it, many thanks.
Old 7th May 2012, 04:41 PM   #5
Brouilly's Avatar
For reference.
My record player has been on the shelf below my amp. When moving the deck around the room the hum disappeared, so I guess it is the PS choke or transformers causing interference?
Deck is now happily away from the amp, and probelm solved... for now.
Charlie
Ground problem Rega RP1Hide this!Advertise here!
Rega Elex problem pointer pphilpot Solid State 18 29th November 2011 11:24 PM
Rega arm cueing mechanism problem KKG Analogue Source 6 25th March 2009 07:24 AM
Luxman A-522 Rega Clone speed problem kffern Analogue Source 3 2nd October 2007 12:01 PM
no ground problem trancy Tubes / Valves 2 27th March 2004 01:53 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright ©1999-2017 diyAudio
