Old 12th December 2011, 09:54 AM   #1
Default Ground plane layout for phono pre
Hello,
I am about to build up a phono pre based on the Elektor design from '82 (see schematic).
I designed a board and I am a little unsure about the layout of the ground plane. Attached is a ground plane layout that is separated into input and "power" ground. Another optiom would be a closed ground plane without separated areas.
Any recommendations would be appreciated.
Best regards, Daniel
Ground plane - Upgrade mfrimu Digital Source 7 28th December 2011 03:01 PM
Ground Plane Prototyping keantoken Solid State 9 22nd June 2011 07:07 AM
Ground plane or star ground? yakideo Chip Amps 6 27th March 2011 05:06 PM
Bench Phono Pre Layout boxerboxer Tubes / Valves 0 28th July 2009 04:23 AM
star ground vs. ground plane Sebastiaan Chip Amps 15 10th May 2009 05:05 PM
Page generated in 0.06939 seconds (68.35% PHP - 31.65% MySQL) with 11 queries
