2nd Interesting Link
Old 12th September 2003, 05:00 AM   #1
Audio Addict is offline Audio Addict  Canada
Default 2nd Interesting Link
http://www.theanalogdept.com/susp_tim_bailey.htm
Dennis
Old 27th June 2013, 10:18 PM   #2
Dude111 is offline Dude111
Yes that does seem interesting but wouldnt putting the table ON SPRINGS make it more vulnerable to moving up and down if it feels a vibration?? (Someone stomping on the floor,etc) Might not produce good results!
Old 29th June 2013, 12:36 AM   #3
moray james is offline moray james  Canada
more with springs than without. you got it but you got it wrong. up and down motion is harmless it is lateral motion which causes the problems. So you design a suspension which channels vibration into a plane which does no harm. Best regards Moray James.
moray james
Old 29th June 2013, 01:59 AM   #4
andyr is offline andyr  Australia
Hi Moray, I'm interested to know your opinion of the effect of spring stiffness on the effectiveness of the spring suspension.
What effect would increasing the stiffness of the springs by, say 30%, have (on a Linn-type, 3-point suspension)?
Thanks,
Andy
Old 30th June 2013, 07:02 AM   #5
Yes how silly of me,of course back and fourth would cause more issues!!
Thank you Moray!
Old 30th June 2013, 11:22 AM   #6
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 2nd Interesting Link
Increasing the stiffness of the spring would raise the resonant frequency of the LP12 suspension, moving it closer to the critical arm/cart resonance. Not what you want.
I seem to recall their suspension is tuned 4-6hz, typical arm resonance is 6-12hz.
Paradise Pre-reg PSU PCBs
Old 30th June 2013, 12:14 PM   #7
Thanks, sq - that makes sense.
OK, 2 Qs:
1. What will I notice happening, if the arm/cart resonance was the same as the resonant frequency of the LP12 suspension?
2. If I don't notice any difference in the arm/cart resonance (when playing a test LP) ... then presumably whatever springs I have used in place of the stock Linn springs have not moved the RF too close to the arm/cart resonance?
(BTW, I do have a specific reason for asking these Qs! )
Thanks,
Andy
Old 3rd July 2013, 06:35 AM   #8
Thanks,
Andy
Andy: if you use stiffer springs in your table and your moving mass is kept the same then the rate of frequency that your suspension resonates or bounces at will increase in frequency so the table will bounce faster. Use softer springs and the table will bounce at a slower rate, You want your bounce to be at a lower frequency than your arm cartridge combination. You arm or cartridge maker should be able to tell you what your combination of arm and cartridge will resonate at tune the suspension 2 -3 Hz. below that.
The Analog dept has some of the best tweaking info you will find on line so check them out. It has been decades since I have done any of this stuff so if I am in error forgive me I will be happy to be corrected but I think I have it right. Best regards Moray James.
moray james
Old 3rd July 2013, 09:30 AM   #9
Andy: if you use stiffer springs in your table and your moving mass is kept the same then the rate of frequency that your suspension resonates or bounces at will increase in frequency so the table will bounce faster. Use softer springs and the table will bounce at a slower rate, You want your bounce to be at a lower frequency than your arm cartridge combination. You arm or cartridge maker should be able to tell you what your combination of arm and cartridge will resonate at ... tune the suspension 2-3 Hz. below that.
Thank you, MJ - very interesting information which makes sense to me!
So, if I can paraphrase what you said:
a) if I use my test LP to find the Hz (vertical & horizontal) that my cartridge oscillates at, in my new 12" UP arm on my new 'SkeletaLinn' TT, then
b) if this oscillation behaves in exactly the same way as it did with (the same cartridge in) my LP12 ... my new 'SkeletaLinn' (with stiffer springs) plus 12" arm combo must have a perfectly acceptable suspension resonance?
Am I correct?
Thanks,
Andy
Old 3rd July 2013, 09:42 AM   #10
ashok is offline ashok
ashok's Avatar
Default Horizontal damping
At the 2011 RMAF I think it was Oracle who was showing the effect of horizontal damping. The difference between no damping and some damping was quite audible. It kind of locked the image in space ! The damping adjusted too little or too much killed the effect. I was impressed !
AM
2nd Interesting LinkHide this!Advertise here!
interesting link?! samoth Digital Source 2 13th June 2006 08:21 PM
Interesting link Etacovda Multi-Way 0 6th January 2006 08:30 PM
Interesting Link Audio Addict Solid State 1 22nd September 2003 08:39 PM
Interesting Link Audio Addict Analogue Source 12 11th September 2003 09:26 AM
Copyright ©1999-2017 diyAudio
