Old 24th November 2011, 06:52 AM   #1
Default Wich ways to turn your DIY turntable
Hi everyone,
I was thinking about doing a DIY turntable but I keep thinking about one problem , what way to drive the turntable.
What ways are possible (AC/DC motor , flywheel , ...)
and which do you have ?
some more info about my design includes a 20 kilo / 44 lbs platter, belt driven.
thanks Matthias,
Old 24th November 2011, 08:29 AM   #2
Joao@AltheaMusica's Avatar
20KG platter means first thinking in designing a bearing (invers, magneticm air ...) and then you can try out several motor variants.
Old 24th November 2011, 08:52 AM   #3
This is what I was thinking for the bearing :
Brass casing, with a polished steel spindle at the bottom will come a steel ball and a 2 mm tick delrin plate.
The cut outs that you see in the middle are to minimise friction and help to lubricate the spindle
Old 24th November 2011, 09:12 AM   #4
How much is the diameter of the spindle? Forget the Delrin plate it will not work properly with that heavy platter. I'd recommend a gardened steel plate here as well - and by the way a rounded spindel instead of a ball pivot is pretty good.
Old 24th November 2011, 09:16 AM   #5
for spindle diameter I took 25 mm, so you wouldn't use a ball ? and nu Delrin ?
Old 24th November 2011, 09:21 AM   #6
Just did a quick calculation of the weight of the platter and I think I will get it to around 15 kilo
Old 24th November 2011, 03:42 PM   #7
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
This is more or less the same as the original Teres bearing - 3/4 inch with the early versions, then later increased to 20mm.....
My bearing ( still unmounted ) have a regular 12mm bearing ball recessed into the pivot end.....
20kg is rather on the heavy side, though, - just wondering what there really is to gain with the last 10kgs..... except for visual impression
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 25th November 2011, 08:26 AM   #8
With my current 12KG platter I tried several combinations including Ruby etc. and I use now a rounded spindle (in reality that's the same like a ball) and a hardened steel plate. It runs perfect.
For use of a 20KG+ platter I'd recommend not such a bearing we are discussing here. Have a look on hydrostatic or squeeze film bearing. Others are magnetic or air bearing....
Old 28th November 2011, 07:51 AM   #9
yes indeed what there is to gain with more mass ? more stability less vibrations ? this if you have an excellent bearing of course
Old 28th November 2011, 07:53 AM   #10
Is the rounded end of your spindle hardened ?
First DIY system: 4-ways! Peerless, HiVi, TangBand, Fountek Candisa Multi-Way 94 11th September 2011 12:27 PM
DIY turntable using parts from DIY Hi Fi Supply gadfly Analogue Source 6 9th August 2009 04:59 AM
Different ways to constrained layer construction/ damping - Wilson Audio v DIY rick57 Multi-Way 12 20th March 2007 02:40 AM
pics of DIY 3-ways w/ 1354 wideband 3-LockBox Multi-Way 0 1st August 2006 07:44 PM
Wich DIY speakers do you use and/or recommand with a Zen V4? Bricolo Pass Labs 7 17th December 2002 09:27 PM
Page generated in 0.10648 seconds (79.47% PHP - 20.53% MySQL) with 10 queries
