| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
How do you listen to your Modern Mono records to get the best results?
i.e. a mono recording that has been cut on a stereo lathe Do you use a mono stylus or stereo stylus with a Mono-Summer of some kind or just use a stereo setup all the way through? I'm just really just trying to work out what is considered the prefered/best way to do it. |
#2 |
Well i recently bought PE/DUAL3044 for the $8 a bit of basket case needed a new catridge and stylus and new mounting head, plus a good regrease and setup.
Anyway i have rewired it as mono coming from a BSR SC5H and a ST14 stylus and i have to say it does sound good through my mono valve amp. I play a lot of older lps from the late 1950s and early 1960s and a lot are mono so this setup seems to work for me. I was more concerned about having a deck that was well built and stable, ive always liked Dual turntables so i thought for $8 it was worth my time. just my thoughts hope it helps. |
| Modern PC DAC vs "Audiophile DAC" | TheLaw117 | PC Based | 140 | 17th September 2011 04:24 PM |
| Vinyl wrapping - which vinyl? | Frosteh | Multi-Way | 1 | 22nd August 2011 06:52 PM |
| DIY Audiophile Series: How to Make Your Own Audiophile Quality 300B Valve Amp (4DVD) | scav | Swap Meet | 1 | 12th October 2009 03:14 PM |
| difference between mixed mono and summed mono | Clipped | Car Audio | 4 | 10th October 2007 11:34 AM |
| Dual Mono - Anti Mono Power Supplies | pmkap | Everything Else | 3 | 16th February 2002 05:10 AM |
| Page generated in 0.06990 seconds (67.17% PHP - 32.83% MySQL) with 10 queries |
