Old 26th December 2011, 11:28 PM   #31
wrenchone's Avatar
Here's a picture of the board in question in a clamp on the bench, getting ready for gain-phase measurements. Schematic will follow in a bit.
Old 26th December 2011, 11:33 PM   #32
wrenchone's Avatar
Here's the gain-phase plots. The 1kHz gain between the two channels is off by ~0.4 dB. I'll be trying to bring that closer by better matching between jfets and also for the current sources feeding them. Meanwhile, I want to throw the current revision preamp into my system to see if the extra care will be worthwhile.
Old 20th January 2012, 05:26 AM   #33
wrenchone's Avatar
I picked up 100X NSC 2n4391s from a Chinese E-pay seller - It'll be interesting to see how they test out. The NSC PN4391s I've tested have so far been on the "hot" side in terms of Vgs for a modest drain current.
Old 2nd February 2012, 11:09 PM   #34
wrenchone's Avatar
Hese's the 4391s I got from a HK E-pay seller. I wish I had bought more of them when they were as common as dirt ~20 years ago...
Old 2nd February 2012, 11:38 PM   #35
bcarso is offline bcarso  United States
Apparently National Semi if they are genuine. Can you decode the date of manufacture?
Old 2nd February 2012, 11:52 PM   #36
wrenchone's Avatar
Date code may be 9411. I don't know when National unloaded their discrete lineup, but if this date is after that, then they would be fakes. I don't see why anyone would bother to put fake fets in gold-plated TO-18 packages, though, unless these parts are some other device that was scrubbed clean and re-marked. I plan to put a couple through my fet tester to see if they make noises like a typical 4391. This may not happen until I get back from a business trip to China. If they are legit, I have just the heat sink for them...
Old 2nd February 2012, 11:58 PM   #37
I suspect they are real.
Old 3rd February 2012, 12:11 AM   #38
wrenchone's Avatar
I did a little digging using Google, and it appears that National dumped their discrete lineup in 1996 when they spun off Fairchild as a separate entity.
Old 4th February 2012, 09:41 PM   #39
If those are still available I'd be interested in the contact. Also, if you find it convenient I'd like to know what their typical drain-source breakdown voltage is running (don't destroy one in the process, but say when does the drain-gate zener with a 10M resistor in series?).
Clearly, I don't have these in mind for a production run
Brad
Old 12th February 2012, 05:30 AM   #40
wrenchone's Avatar
Easy, just search for 2N4391 on E-pay. The source is the only one offering National 2N4391 in quantity. The price is merely obscenely extortionate as compared to hilariously extortionate. If these are real 4391s, they are rated for 40V, though no doubt some will break down at a higher voltage.
Folded Cascode in the Making wrenchone Solid State 11 6th March 2010 01:11 AM
folded cascode the_tool Chip Amps 1 27th June 2006 09:53 PM
Symmetrical folded cascode. Mr Evil Solid State 195 1st April 2005 03:15 AM
Folded Cascode Sound? wrenchone Solid State 16 26th February 2004 05:56 AM
Page generated in 0.10562 seconds (79.24% PHP - 20.76% MySQL) with 11 queries
