| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I plan to purchase a Technics SL-1600 locally sometime this week. Here is my problem: My knowledge of record players (in general) is limited to knowing how to start the song .
Is the Technics (usually) a reliable unit to begin with? Which parts would you recommend I replace or upgrade for at least "acceptable" playback quality? Any and all help is greatly appreciated, and I thank you in advance Don
- "Think inside the box"
#2 |
Mostly be aware that used tables can have hardened lubricants, stiff arms and bad connections. Most don't, but just be on the lookout for things that don't work smoothly or the way it seems they should. Check out Vinyl Engine.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
Usually they're reliable,but the arm auto-lift almost never works, since they use a rubber band that desintegrates with time, but it's easy to replace
And that one is automatic, but without a replacement of the rubber band it will not work in auto |
#4 |
What a great link Conrad, thank you!
And thank you both for the info! Will I need a preamp for this unit? Again, sorry for the newbie questions; I want to make sure I get everything just right. And more importantly, I want to know what I'm getting myself into!
#5 |
Yes, you'll need a phono preamp (aka RIAA preamp or preamp with RIAA frequency characteristic).
The only lower priced, commonly available turntables I know of that have built in preamps are the very cheap ones you'd find at Best Buy or the like. A Technics SL-1x00 will be a very different beast, and much better. Will you get to try the turntable out before you buy? If so, spin a record, see if it plays OK, and sounds good to you. It should sound at least pretty good, i.e. "clean." Carefully move the tonearm around a little (carefully...). It should move very smoothly, with extremely low friction. Good luck with it. I snagged an SL-1200MK2 from the next-to-last year before they stopped making them, and I do like it a lot. |
#6 |
Thank you rongon. Unfortunately, the seller says "it needs a needle". I assume he means a stylus, but regardless I won't be able to test before I buy. If it is any consolation however, he is only asking $55 for it. I hope that is a fair price..
And from a quick google reference, it seems (overall) that "vintage" preamps came with the RIAA you speak of, and it is quite lacking with the newer preamps unless specified. Any truth behind this? Additionally, as I am trying to be frugal with my audiophilia , I've sourced a Mitsubishi DA-C7 tuner/preamp for close to $100. Would you (or anyone) recommend a newer or better suited preamp in that price range? Thanks very much again everyone!
#7 |
I may be in luck! The receiver I use is an Onkyo TX-DS777. In the owners manual it states:
3. Turntable This receiver is designed for use with turntables using moving magnet cartridges. Connect a ground (or earth) wire to GND terminal. With some players, connecting a ground wire results in larger noise. If so, do not connect any ground wire. Does this mean that I've just lucked out of having to buy a preamp? (fingers crossed)
#8 |
Yep. You are good to go!
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
| Vinyl wrapping - which vinyl? | Frosteh | Multi-Way | 1 | 22nd August 2011 06:52 PM |
| Vinyl searching? | mikje | Analogue Source | 2 | 16th March 2009 06:28 AM |
| Vinyl shops | gchrist | Music | 10 | 16th October 2007 06:59 PM |
| Portable vinyl playing solution suggestions? | kaban | Analogue Source | 3 | 29th November 2006 03:55 PM |
| vinyl recorder | sss | Analogue Source | 0 | 30th May 2005 10:38 AM |
| Page generated in 0.09519 seconds (76.04% PHP - 23.96% MySQL) with 10 queries |
